Baader D-ERF with Lunt etalon and trimming filter?
Jdgoguen
Post by Jdgoguen » Sun Feb 14, 2016 3:44 pm
Hello All. My first post to this forum. I have just purchased a used Lunt LS50FHA etalon, without the blocking filter. Rather than buying the blocking filter, I'm considering getting a Baader D-ERF to mount in front of the etalon and a trimming filter to mount near the eyepiece. The D-ERF would be large enough to cover the full aperture of the scope. Although this would be a bit more expensive than buying the blocking filter, it would leave open the option of converting the etalon (with the addition of field lenses, etc) to internal use giving me full aperture resolution. The D-ERF may also be use full on its own. I have a milling machine and lathe, so making the adapters to fit the etalon to the objective and the large filter in front of the etalon for initial use is not a problem.
Is there any reason to expect this arrangement would be inferior to just getting the stock blocking filter?
Thanks in advance for your comments,
Jon
Re: Baader D-ERF with Lunt etalon and trimming filter?
Post by marktownley » Sun Feb 14, 2016 10:37 pm
what trimming filter do you plan to use?
Jdgoguen
Post by Jdgoguen » Sun Feb 14, 2016 10:52 pm
656.3nm center 0.7nm FWHM 25mm dia.
Jon
Post by Valery » Mon Feb 15, 2016 7:30 am
Jdgoguen wrote:656.3nm center 0.7nm FWHM 25mm dia.
Jon
What is the brand of this filter? And the price?
Jdgoguen
Post by Jdgoguen » Mon Feb 15, 2016 3:33 pm
A few are available from bjomejag on Ebay, item #151278728955 for $135. He sells overstock and cosmetic seconds from Omega, a large filter manufacturer, and provides a measured transmission spectrum with each. I have purchased filters from him for use in very sophisticated microscopes and that have been fine, but of course the specs were not as demanding. Seems worth a try.
Jon
Jdgoguen
Post by Jdgoguen » Mon Feb 15, 2016 3:55 pm
