So someone said that using a PST etalon modded telescope there was no point going beyond 5 or 6in I believe because any larger would get you nothing due to the size of the etalon. Is that right?
Speaking of maximum resolutions, I would guess at some point more pixels in your camera will do nothing for you when imaging, does anyone know what those limits are or how to calculate?
Maximum diameter or optical resolution possible with a PST modded telescope?
Re: Maximum diameter or optical resolution possible with a PST modded telescope?
The size of the suns disk is roughly 1/100 the focal length. In a PST mod the etalon must be placed -200mm inside prime focus and the recommended focal ratio is f10.
This means the size of the solar disk at the etalon will be (200/10 +fl/100)
The etalon is just 20mm diameter, so longer focal lengths will lead to more vignetting and light losses.
Re cameras - to me it comes down to plate scale (arc sec/ pixel) and there should be enough "total" pixels to record the size of the image you want.
Craig Stark's CCDCalc is a great starting point for these calculations.
http://www.newastro.com/book_new/camera_app.php
Very happy with my 6" F10 PST mod. Definitely better than my smaller ones under most conditions.
I think anything beyond 6in is pointless, so you did good..
I understand the pixel dimension to size of image etc, but what I'm saying is with say a Solarmax 60 telescope and under normal air conditions, I think there is some limit to amount of resolution you can get, thus a camera beyond X? pixels is pointless..
I'm not sure I understand the second part of your question...
The resolution you obtain will be a result of the seeing conditions, the optical resolution of the objective you use and effective sampling with the camera CCD pixels.
When you say "beyond X pixels" what do you mean? The number of pixels in the CCD array? the size of the pixel?
Help me.
Help me.
