Will this crazy 'Mod' work? Your constructive criticisms much appreciated.
- robert
- Has thanked: 4 times
- Been thanked: 1275 times
Re: Will this crazy 'Mod' work? Your constructive criticisms much appreciated.
Again trying to use my TV101 and my 40mm BF10 Filter set. Wonder if this would work!
90mm ERF filter - TV101 - 2" Barlow Lens (push f5 to F10) - 40mm Coronado Filter - BF10
What is this 40 mm Coronado filter? If it is a front filter then this idea will not work I'm afraid.
It will work, without the barlow and with a plano convex lens as in Rogerio's diagram to make the rays parallel at the front face of the SM40.
Robert
Robert
- robert
or even with the barlow maybe
R
R
[quote]Again trying to use my TV101 and my 40mm BF10 Filter set. Wonder if this would work!
Robert
Well, I don't think so as I am not talking about putting a complete telescope after the Plano convex lens. I am trying to use just this filter set.
Robert
This is exactly what Rogerio did in his setup. I am trying to contact him, maybe he will join this discussion.
best regards
best regards
- robert
Ah sorry, crossed threads... you need another scope to make it work! I agree
Robert
Robert
- Has thanked: 20813 times
- Been thanked: 10485 times
Rogerio uses a 150mm F/15 refractor that converges to a Coronado SM40. Th interesting inovation is the use a single convex lens before the SM40. No ERF is needed in this case.
http://www.astroimagem.com/Mybestimages ... daicon.jpg
A- 150mm F/15 Achromatic objective
B- Prims and mirrors
C- Simgle plano-convex lens and Fabry-Perot filter (maybe a SM40 or SM60 not sure which)
D- 60mm F/15 refractor
E- LU-075 CCD camera
F- computer
best regards
This is the way i'm seriouslly considering going with Ha setup - i have all the components apart from 'C' the plano convex lens' problem is I don't know what specification of lens to get or where to get it from for it to work in my system...
F- computer
best regards
I am trying to get Rogerio into SolarChat. Sent him several emails but no answer yet.
best
best
I guess you are right. Let's wait for Rogerio's answer.
best
best
To my understanding this depends on the primary refractor that you are using. If that is a F/6 then the planoconvex lens should also be F/6 in order to achieve parallel rays to enter the etalon.
It would be nice to have this confirmed by Rogerio though.
Hmmmm, that makes obvious sense really doesn't it - good logic there Neo!
My Meade 127mm is 1180mm fl so f9.3, however if I stopped it down to 118mm then it would become f10, and finding a ~50mm f10 objective lens to use should be comparitively easy... From then on it is just 'plumbing' to connect all the components together. I need to give this some serious thought...
I want to be able to do this without the 2nd telescope. We put filters in front of our CCD and not at the front of the telescope.
I know heat is the issue so an ERF in the front. Having a long enough FL Objective to not shift the bandpass very much when the light enters the Coronado Filter and then the BF10. I would like to figure it out without two objects.
Time to contact my good friends who make optics and filters.
hmmm I am not an expert but why would you not just move the fiter and blocker back far down the optical path without the 80mm objective. This would kind of being like a filter in a filter wheel ?
No, you couldn't do this Ken, the light entering what are designed to be external etalons like the sm40 needs to be parallel, or, well nearly parallel, actually f108...
Incidentally i've just picked up off fleabay a 50mm f10 objective lens, which with shipping from the states comes in at ~£10 - bargain! I have an old 2" barlow which I can swap the just bought lens for the existing element and once inserted into the focus of the 127mm meade (which I will step down to 118mm) will give me an output beam of light that is parallel. This can then be piped into the front of my existing Ha scope...
I can see this being my project over the Christmas holiday...
[quote]hmmm I am not an expert but why would you not just move the fiter and blocker back far down the optical path without the 80mm objective. This would kind of being like a filter in a filter wheel ?
Thanks for that - F108!!
I just got off the phone with my good friend Don Goldman (Astodon filters) and he said the same thing, that the bandpass shift would be moved to much out of phase.
Hmmmm, two objectives - this is interesting for sure.
Thanks again!
Thanks again!
My plan is to use it in the configuration as per Rogerios http://www.astroimagem.com/Mybestimages ... daicon.jpg rather than the configuration David Evans proposed at the start of the thread. The 50mm should work in this manner, my plan would be to mount it on the front of my DS40 etalons in a folded light path @ 500mm behind the fp of the meade...
Yes, the convex element design would be better - would this have to have the same focal ratio as the primary objective?
Hello
First I want to thank Pedro Re for inviting me to join this list. Here you can discuss changes in the telescope without danger of being excluded. Thanks Stephen!
My system is simple. Do not use rejection filter. The important thing is to always work with f/10 throughout the system. The small refractor is about 500mm focal length (f/10), the PCX lens also has the same focal length and 50mm diameter. This is a collimator lens and produces a beam parallel to the etalon. Formerly used an SM40, but recently replaced it with a Lunt LS50 BF1200 filter.
The PCX lens is obviously 500mm away from the image generated by the large refractor, a 200mm diameter and 3000mm focal length. It's an old AS200 Zeiss.
To reduce the heat on the etalon, I use an aluminum plate with a small rectangular window about the size of the CCD chip at focal plane. Thus, much of the image is retained on the plate and only through what will serve for the camera.
The PCX lens works perfectly because color correction is not necessary and is not observed spherical aberration or coma.
The secret is to keep all the lenses at f/10 or f/15 and use aluminum foil with a window to heat retention.
For images, I use the camera Lumenera LU075M capturing 3000 frames at 50 fps. I usually do a central image and the four quadrants, then assembling the mosaic with iMerge software.
Best Regards and clear skies
Rogerio Marcon
Rogerio Marcon
- solarchat
- Site Admin
- Has thanked: 84 times
- Been thanked: 1384 times
Rogerio! The worlds best solar imager...hands down!
WELCOME!
WELCOME!
Stephen W. Ramsden
Atlanta, GA USA
http://www.solarastronomy.org
Atlanta, GA USA
Thanks for joining up and explaining your system!
One question, would adding an ERF to the front to limit the heat and not use the aluminum plate be ok?
Welcome Marcon and thanks for your post. Everything is more clear now (at least to me).
best regards
abraço amigo
best regards
abraço amigo
best regards
abraço amigo
Yes, indeed, thank you. The whole f-ratio thing makes absolute sense.
best regards
abraço amigo
Thanks guys
Ken, I think that it is possible to use an ERF. I do not have one and I could not test this alternative.
The disadvantage of my system is its size. The total length exceeds 4 meters and I used a flat Zerodur mirror to bend the tubing in half because it would not fit in the observatory.
Blue Skies
Rogerio Marcon
Blue Skies
Rogerio Marcon
OK, all this talk really got me thinking last night, and after ordering my lens i decided to try and mechanically configure all the parts I would need to make a system the same as Rogerios. The good news is that it seems pretty easy: In order to bend the beam path through 180o I was able to use two 2" diagonals, this also allows me to align the beam from the big frac with the etalons. The 50mm f10 objective would sit (at correct distance) between the 2nd diagonal and the etalons on the second scope - this would mean the etalons receive a collimated beam. I've took some pics so you can see what I mean...
DSCF2345 by Mark Townley, on Flickr
DSCF2346 by Mark Townley, on Flickr
DSCF2344 by Mark Townley, on Flickr
DSCF2343 by Mark Townley, on Flickr
DSCF2342 by Mark Townley, on Flickr
DSCF2341 by Mark Townley, on Flickr
DSCF2340 by Mark Townley, on Flickr
If this works out I will be one happy bunny as will be able to work at 120mm aperture 0.5a - that could be fun!
Hi Mark
very funny see my pic of almost the same. I'v gotten an first light but never reached good focus
first light
have fun and please report
first light
Great minds think alike Walter!
What is the big frac you are using there? And is the lil' scope a 60mm lunt?
The focus in the image seems ok to me - would you say the focus issue was a combination of large aperture and low sun / poor seeing or as a result of how things were set up mechanically?
Nice setups Mark and Walter. Please keep us posted.
best regards
best regards
Hi Mark
thank you very much. You are guessing right. It is my 152 Apo f/8 and the LUNT 60. In front of the LUNT 60 there was the edmund lens placed.
I think my wodden construction was not aligned correct enough to give a good focus. Of course using a scope mit 152 mm is not for everyday seeing.
On top of that I did not play / optimize the distance 2nd diagonal to LUNT 60.
I'm so happy that we can discuss these things here in the forum.
Think about the consequences we did that withhin CN
Hi Walter, thanks for the info!
Looking at your picture all the angles of dangle look ok to me, I wonder if the focus issues you were having were just a result of that 152mm aperture?
I have been thinking about the spacing of the edmund lens with respect to the focal point myself; I initially thought I would have to place it 500mm behind the focal point, however as this is a 50mm f10 it would give me a 50mm collimated beam - I would be wasting light (and resolution?) here as my etalons are 40mm, so, have decided to mount the edmund lend ~350mm behind the focal point; this will give me a collimated beam ~35mm diameter, which is a much better match for my etalons and also gives a bit of leeway incase of slight mechanical misalignment...
I'm glad we can talk about this too - we would have all been banned on CN had we even dared think it...
Incidentally, this is the edmund lens I bought
http://www.ebay.co.uk/itm/230446149304? ... 1497.l2649
A bargain I think!
A bargain I think!
Hi Mark
very interesting. I bought another lens. I'll show it later to you and the members here. Rogerio helped me setting up this scope. (thanks again Rogerio)
It's time to me to hit the pillow
- robert
I think you need the lens to be 500mm beyond the image plane to get parallel rays, at 350mm they will be diverging
Robert
Robert
Robert
I reckon you're onto something there Robert, my brain is coming up with ideas quicker than i'm reasoning with them. Maybe the 40mm f10 lens from my CaK PST would be a better match to my etalons - hmmm...
Robert
The 40mm CaK PST objective (and hacked gold tube) seems to be a nice tool for this job: geometry wise it fits in nicely and seems to be just the right size. The white tube sits over the etalons and the end of the PST objective to line everything up...
DSCF2348 by Mark Townley, on Flickr
DSCF2347 by Mark Townley, on Flickr
Now all I need is first light...
Amazing ~ LOL that is going to be interesting. Looking forward to your first light.
- robert
me too! B)
me too! B)
I really think we are on to something here guys....
I can see us all ending up with large solarscopes!
Great teamwork.
Great teamwork.
Yes, it will work. My first prototype used two prisms. Later I switched to a single plane mirror.
My system was originally based on the optical telescope OSPAN (ISOON):
http://nsosp.nso.edu/ospan/images/ospan-optics.gif
This is a way to get high resolution with small filters. The disadvantage is the size of the telescope.
Clear Skies
Rogerio Marcon
Clear Skies
Rogerio Marcon
Excellent, glad you think it will work Rogerio, this reassures me!
If the only caveat is the size of the scope then this is something I will happily live with, my mount regularly is 'double scoped' and is happy with the weight so all is well there. I really can't wait to try 118mm @ 0.5a, I have a feeling the view compared to the 40mm i'm used to is going to blow me away!
I would like to recommend an online optical ray tracer applet
http://www.arachnoid.com/OpticalRayTracer/index.html
The applet can also be downloaded to run as a local application from your hard drive.
Dave
Dave
Hi David
thank's I'll have a try
- Been thanked: 171 times
Ok after reading all this I'm beginning to understand whats going on. Mark and Walter when you've worked it out is it posible to produce a line drawing with all lenses mirrors filters etc and measurements as well as the light path. That is does it stay parallel all the way or converge then diverge on its way to the focal point. Also is there a focal point near the base of the first scope or is this nullified and the rays remain apart until the focus of the second scope.?,
Derek
Derek
Yes Theo, the ideal would be to have a PCX lens at f/15 getting the beam with a diameter of 50mm, but at f/10 works well. Because the source is not as punctual as a star but a small rectangle, the parallel beam is slightly wider than the 33mm. There is no light loss.
You could not use an f/D greater than 15 for the PCX lens because it would result in loss of part of the beam.
Regards
Rogerio Marcon
Regards
Rogerio Marcon
Hi Derek
thanks for the job :-). I have given up the system a year ago because I got a LUNT 100 which is great and have sold my LUNT60 with the 50 double stack. So I can't go this way again.
In the meantime I'm working on a 127 and 152 FH both f/10 with eighter the PST etalon or the new Ha filters from Robert Johnson. The Ha filters from bob are not yet mounted, because the tilting mechanismen from Israel have not yet arrived.
Winterime is experimental time, so I'm looking forward to interesting news :-) I'll report in that forum. Where else :-)
Hi Derek,
If this is successful as I hope it is will definitely get some schematics up - but, bear in mind, this will be specific to my particular optical configuration, though, as I understand easily adaptable and configurable to different optical systems...
All being well I hope to test it on saturday morning in my 'hour window' - will keep you updated...
- Has thanked: 174 times
- Been thanked: 619 times
I have images somewhere of a EC90 (El Cheapo) 90mm folded design using a SM40 etalon (later double stacked with a PST etalon)
I found the double diagonal trick to be a problem...they didn't give me 180 degrees.
I used a couple of 50/50 front surface mirrors ( cut down the heat loading and fully adjustable)
The first prototype was based on a TV Big Boy x 2 barlow to give the necessary parallel collimated beam to the SM40 but again I found this to be a poor decision...the double positive lens is definately the way to go.
We've also been playing with a LADS and LASS concept - Large Aperture Double Stack and Large Aperture Single Stack where a sub-diameter ERF is used.....
Great to have you here Ken!
Hopefully the weather will oblige over Christmas and will be able to test this thing out. I hear what you're saying about the 2 diagonals not being 180 deg and can imagine the issues it will create - couple of mirrors could be a thing to look at...
You got any details on LADS and LASS you could link to? There are alot of people here who would find it interesting
Most of the discussions were on the SGL forum in the UK
http://stargazerslounge.com/diy-astrono ... scope.html
Some very interesting discussion on that thread, thanks for the link Ken
Just to give an update on this: I tried a 'first light' with my setup last weekend however could not acheive focus. Believe the issue to be the exact position of the collimating lens prior to the etalon. As soon as sun is out for long enough I will have another shot...
I was naturally really impressed by Rogerio's results and had been contemplating a larger aperture than my original 90mm PST mod. I have a 220mm F12.5 achromat refractor and experimented with a 80mm ERF before the PST combination. The results were outstanding visually but the ERF got uncomfortably hot. I eventually rigged up a stand alone cold air blower feeding into an aperture through the side of the main tube, this kept the ERF reasonably cool for the duration of the observations. To try and work around this complication I placed a 140mm ERF as close to the objective as possible without vignetting the focal beam, at this position there was no noticeable thermal problem. I would not advocate this aperture for regular use in the seeing conditions we usually have in the UK. I am at the moment trialling a 150mm F10 PST mod with a 110mm Baader ERF as a subdiameter unit and a BF15 to improve the field of view. The Istar objective was purchased brand new, all other components were good secondhand, total cost £1450.
