Is the blocking filter necessary?
NightPhotographer
Post by NightPhotographer » Thu May 12, 2016 3:16 pm
Hello
I want to get a Lunt H-Alpha filter for solar imaging. Since I am not going to use my telescope for observing, I'm not sure if I need to buy the blocking filter as well. Is the blocking filter only a safety measure for solar observation?
Re: Is the blocking filter necessary?
Post by Merlin66 » Thu May 12, 2016 4:29 pm
<name?>,
The H alpha filter system is a combination of an ERF, an etalon and a blocking filter.
It needs all the elements to function. You definitely need both the front Lunt H alpha filter element plus the rear blocking filter for both visual and imaging.
Post by marktownley » Thu May 12, 2016 5:49 pm
Yes you do need a blocking filter.
Users browsing this forum: Bing [Bot] and 2 guests
