PST or Lunt components?
Bassoon
Post by Bassoon » Fri Oct 28, 2016 11:27 am
I am converting a 100mm ED refractor for solar use. Hope someone can advise.
Would a Coronado PST or a Lunt 50 pressure scope be preferable at the business end? (Lunt 100mm ERF over objective).
The Lunt has the B600 filter - is this wider than the PST filter?
Is use of a focal reducer viable to change the focal ratio to suit the Lunt better?
Any advice welcome, thanks.
Re: PST or Lunt components?
Post by marktownley » Fri Oct 28, 2016 5:58 pm
PST is easier mechanically. Depends how competent you are with such things...
