Skywatcher StarTravel 102 + Lunt LS50THa good combo?
soulvagabond
Post by soulvagabond » Wed Nov 23, 2016 6:06 am
Hello everyone.
A few weeks back, I have discovered about the amazing Alpha-H watching world and been doing a lot of reading ever since.
The easiest solar scope for me to get is the Lunt 50, which will be arriving in about 2 weeks to the store of my choice.
Now, to be honest, I much prefer the close up images of the sun in Alpha, so the larger aperture mod is a must do.
The owner of the shop offered to perform the Lunt larger aperture mod for me, for about $150 plus the cost of the parts.
The parts to be used are:
Lunt LS50THa
Lunt 100mm ERF filter
Some custom adapter
I know the guy does a lot of custom telescope work, but, looks like it will be his first solar conversion mod.
So, I thought I better ask here, before pushing the green button.
Particularly, how well the StarTravel 102 F/5 Focal Ratio, 500mm Focal Length will suit that of the Lunt scope?
Will the B600 filter suite better for this conversion compared to B400?
Also, to mention, this will be used 100% for visual observation, and DS will not be done in near future, due to the budget limitation.
Any suggestions and criticism are welcome!
Re: Skywatcher StarTravel 102 + Lunt LS50THa good combo?
Post by marktownley » Wed Nov 23, 2016 11:37 am
The Lunt 50 is an f7 scope, and so you will get enhanced sweet spot effects by using an f5 donor scope. You would get best views stopping it down to 70mm to reach f7, but you really aren't getting much resolution increase, if i'm being honest.
How do you plan to mate the 2 scopes together? I had the 100mm scope you talk about and the focuser is rubbish - I wouldn't want to be hanging another scope off it.
The B600 would be the better option!
soulvagabond
Post by soulvagabond » Wed Nov 23, 2016 1:06 pm
So, what the ideal donor's focal ration to use with the lunt then?
Post by marktownley » Wed Nov 23, 2016 8:01 pm
f7
soulvagabond
Post by soulvagabond » Fri Nov 25, 2016 8:35 am
Thanks guys!
Another question I have, is there any danger in using either Lunt based 102mm mod or 102mm + Daystar Quark, without the front mounted ERF?
