minor issue with imppg
rbenton
Post by rbenton » Tue Apr 04, 2017 6:46 am
I have been using imppg, but suddenly I can no longer call up the tone curves tool. I un-installed it and re-installed the latest version but still no curves tool. When I click on its icon, there is a subtle 'blink' but then, nothing. Has anyone else had this issue? Any ideas how to correct it?
Thanks to all.
Randall Benton
GreatAttractor
Re: minor issue with imppg
Post by GreatAttractor » Tue Apr 04, 2017 5:11 pm
Randall,
Please check your message box.
My software:
My images
Post by marktownley » Wed Apr 05, 2017 10:45 am
I'm using version 0.4.1 and the same happens with me too?
GreatAttractor
Post by GreatAttractor » Wed Apr 05, 2017 4:53 pm
The only cause I can think of is some recent Windows update that interferes with window positioning. ImPPG remembers the last tone curve window's position and restores it on startup. Try deleting the ImPPG settings file:
C:\Users\<username>\AppData\Roaming\imppg.ini
and let me know if it helped.
My software:
My images
GreatAttractor
Post by GreatAttractor » Wed Apr 05, 2017 5:28 pm
The AppData folder is a hidden folder, so you may not see it by default. I don't have a Windows 10 installation to verify this, but once you open the c:\Users\<Username> folder, in the folder's window there should be a "View" menu, which contains a "Hidden items" checkbox. After ticking it, "AppData" should be visible.
My software:
My images
rbenton
Post by rbenton » Thu Apr 06, 2017 10:51 pm
Thank you very much GreatAttractor! I followed your instructions and now all is well. I changed the name of the file: imppg.ini to: imppg.ini.bak and that did the trick. Thanks again for the help!
Randall Benton
Post by marktownley » Fri Apr 07, 2017 9:37 am
Will have a look this weekend at the fix, thanks!
Post by marktownley » Sun Apr 09, 2017 6:08 pm
fixed! :)
GreatAttractor
Post by GreatAttractor » Mon Apr 10, 2017 2:48 pm
I'm glad it worked. I'll add a menu option to reset those settings from ImPPG.
Also, it's just struck me - this thread doesn't belong in the "Commercial" section ;)
My software:
My images
Post by marktownley » Mon Apr 10, 2017 8:57 pm
You're right, i'll move it to the mods instead ;)
