lunt 50 mod
krakatoa1883
Re: lunt 50 mod
Post by krakatoa1883 » Thu Jul 05, 2018 7:20 pm
A very interesting discussion as I am also considering a LS50 mod. I have few questions if someone would be so kind to answer:
1. I assume the mod is fully reversible that is I can have back the original LS50, am I correct ?
2. Is the red cylinder with the PT knob simply screwed to the LS 50 white tube ? can they be separated easily ?
3. Which M68 adapter would I need for attaching the LS50 rear part to the telescope ? has this part a male or a female thread ?
4. I have seen in the above image a Coronado BF replacing the Lunt diagonal, is this replacement necessary ?
Thanks in advance
Raf
My personal page on Google+
antonello
Re: lunt 50 mod
Post by antonello » Tue Sep 04, 2018 10:35 am
After a long time, during which no one knew if the Lunt 50 had a lens with a single lens or an achromatic lens, I discovered from this image
lunt 50.jpg (236.86 KiB) Viewed 205 times
that even the Lunt 50, like the Lunt 60., seems to have a objective with single lens, and therefore the use of the Etalon of the Lunt 50, together with the two lenses of its collimator, used on a new telescope with an big achromatic objective, will not allow to obtain, in h-alpha, all the quality of the new big achromatic lens ... :(
