Removing barlow from Quark
sulcis2000
Post by sulcis2000 » Mon May 01, 2017 9:03 pm
anyone tried to remove internal telecentric barlow from Daystar Quark?
I have a excellent Quark but in the next future I'd like to use it with a DK/Cassegrain F15 so I need a Quark without internal 4,3X barlow for using a 2x telecentric barlow
Tks
Ale
Alessandro Bianconi
________________
Celestron C14HD Edge
Refractor 228 F8 Truss Tube with D-ERF 110mm
A&M Refractor APO LZOS 130 F6
Daystar Quark Chromosphere version
Daystar Quark Calcium H
Starizona Hypestar
10 Micron GM2000HPS II Mount
Ioptron CEM120 Mount
ZWO ASI294MC Pro
ZWO ASI178M Cooled
ZWO ASI174M
Re: Removing barlow from Quark
Post by marktownley » Tue May 02, 2017 5:12 am
Mine just unscrews...
LTHB
Post by LTHB » Tue May 02, 2017 6:14 am
Mine also unscrewed, but it required a bit of force and a "boa wrench", because the thread was sealed with what looked like red locktite.
Frank
sulcis2000
Post by sulcis2000 » Tue May 02, 2017 8:25 pm
Tks Frank & Mark. Can you show me a picture of Daystar Quark without barlow?
Ale
Alessandro Bianconi
________________
Starizona Hypestar
ZWO ASI294MC Pro
ZWO ASI178M Cooled
ZWO ASI174M
nickatnight
Post by nickatnight » Thu May 04, 2017 9:51 am
I think Daystar may have added a screw on newer models. Mine has a bit of give if I try and twist it, but a screw on the back right by the joint seems to prevent the turning.
LTHB
Post by LTHB » Thu May 04, 2017 10:25 am
sulcis2000
Post by sulcis2000 » Thu May 04, 2017 2:51 pm
Tks a lot Mark for your contribute!
Ale
Alessandro Bianconi
________________
Starizona Hypestar
ZWO ASI294MC Pro
ZWO ASI178M Cooled
ZWO ASI174M
george9
Post by george9 » Sat May 27, 2017 3:29 am
One question is how much of the blocking filter comes off with the Barlow. If I were Daystar, I would have put the blocking filter before (objective side of) the Barlow so that I could use a smaller one, which would mean it should unscrew with the Barlow.
George
MalVeauX
Post by MalVeauX » Sun May 28, 2017 3:19 pm
Anyone with experience with removing the barlow from a more recent Quark, with he screw/bolt on the side? Any issues? If you take the barlow out, does it still have its blocking filter intact? Would really like to know if you can basically take the barlow out and have a quark combo essentially, and then pair it with other options.
Post by marktownley » Sun May 28, 2017 9:13 pm
George
Hi George. The blocking filter is on the end of the telecentric.
sulcis2000
Post by sulcis2000 » Sat Sep 16, 2017 9:19 pm
Anyone has tried a Coronado BF (BF15 or BF30) instead of the original one of the Quark?
Alessandro Bianconi
________________
Starizona Hypestar
ZWO ASI294MC Pro
ZWO ASI178M Cooled
ZWO ASI174M
Post by marktownley » Mon Sep 18, 2017 5:42 am
Yes, it works, but must be before the telecentric.
sulcis2000
Post by sulcis2000 » Mon Sep 18, 2017 7:47 pm
Tks Mark ;-)
Alessandro Bianconi
________________
Starizona Hypestar
ZWO ASI294MC Pro
ZWO ASI178M Cooled
ZWO ASI174M
highfnum
Post by highfnum » Mon Sep 18, 2017 9:08 pm
to LTHB
how did you get black main ring off of red etalon body?
I see a funny looking screw that has a pin like center
i assume you need a special hex wrench ?
does it have a name?
thx JP
interesting topic
LTHB
Post by LTHB » Tue Sep 19, 2017 7:51 pm
I'm not quite sure what you mean: two of the four screws (upper left and lower right) on the left hand side of the second picture in my last post? If yes: I didn't remove these screws/the black ring so far, so I cannot really tell if they can be removed without damaging the filter.
However, for unfamiliar (to me) screws I usually check Wikipedia, i.e. here: https://de.wikipedia.org/wiki/Liste_der ... pfantriebe
The two screws in the black ring look to me like number 12 from the bottom of the long table (called "Torx Plus mit Stift (5 Point Security)") in the wikipedia entry. This type of screw seems to be missing in the English version of the wikipedia entry, or at least I cannot find it there, but I think they are called "5 point Torx" or "5 point security Torx" or something like that in English.
Frank
highfnum
Post by highfnum » Tue Sep 19, 2017 8:45 pm
It's only one side screw
highfnum
Post by highfnum » Tue Sep 19, 2017 8:48 pm
Yes security torx screw
Do they come off by turning left
But is it t10?
LTHB
Post by LTHB » Thu Sep 21, 2017 8:52 am
Sorry, I misunderstood your question! Yes, you have to remove one screw before you can separate the red etalon body from the main black ring (the two parts on the lower left and in the center of the second of the three pictures in my post above). This screw is on the side of the red part, I removed it months ago but cannot find it right now, so I cannot check what type or size it is. I recall that I had to use some force to break the locktite (I think I used a ratchet wrench - bit sets for 5 point Torx are available on ebay, amazon etc.), but otherwise there was nothing unusual about it.
