How to remove internal reflections
DJD
Post by DJD » Sun Aug 13, 2017 1:49 pm
Dear All,
I am re-vamping my optical train in my PST mod. I use 2" UV/IR cut and 35nm Ha filters at various places in the train.
I suffer from some internal reflections and would like to try tilting these components to check if they are the source of the problem.
Stupid question - how do you tilt a mounted screw-in filter ?
David
Re: How to remove internal reflections
Post by Carbon60 » Sun Aug 13, 2017 3:10 pm
Hi David,
Maybe it's possible to slacken off the inner retaining ring and wedge under one side of the glass to get a degree or two? Doing this for each filter, but in opposite directions might give you what you need.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
bart1805
Post by bart1805 » Sun Aug 13, 2017 10:29 pm
Hi David,
Could the UV/IR cut be the source of the problem? At the moment I use a Baader D-erf and the B1200 Lunt blocking filter (with the ITF). When I tried it in combination with the UV/IR cut filter I had internal reflections. Without it I have not got them.
Bart.
Post by Merlin66 » Mon Aug 14, 2017 2:42 pm
You don't need the UV/IR filter......
I have used a CP polarized filter to suppress reflections, sometimes works well.
