Frankencope Tests! (Apologies for absence)
Macavity
Oh, I get it now!
Oh, I get it now!
Post by Macavity » Fri Aug 18, 2017 10:44 am
Hi (again) Folks! (Throws HAT in) :)
Apologies for absence! As often with Astronomy Forum activities,
one cannot be "everywhere at once" (I notice welcome overlap!).
But also perhaps one should have *something to say* as well? :P
In the *interim* I have been producing "composite" disks like:
I also produce the occasional (2x2!) Matrix. Disk / Prominence
animations. White Light (Solar Cont, DS CaK filtered etc. etc.)
But my scopes remain a *modest* Lunt50 & Altair ED66 Frac!
The former (at least) may not change much in the future? lol
So I find my enthusiasm FIRED by ideas of a Frankenscope! :D
Yet it is only recently that I had "the courage" to have a go...
And (amazingly!) it does show signs of actually working... :mrgreen:
The objective is a (much disguised) Skywatcher ST102. I am
making heavy use of "wood technology" for the OTA "bung"!
I HAVE bought myself a nice Baader 90mm ERF and I'm now
working on making a "proper" (tilted) mounting cell for it...
It is thus far a modest increase in aperture / focal length
50mm f/7 to... 70mm f/7 but I have managed to convince
myself it is "better"... or at least progress is being made! ;)
Lunt 50 owners will know that there is "very little space
to operate" with the original Helical Focusser. But I use
the nose-piece of an Antares 3x Barlow for a 2x increase.
Firstly the Lunt50 Barlowed 2x:
Now my "Lunt 70" (Frankenscope!) Barlowed 2x:
Yesterday, I threw caution to the wind (Yay Sunspots!)
As a "control" re. seeing etc. I took an image with my
ED66 (F=400mm) Barlowed approx 3x for White Light:
And now my MIGHTY 70mm f/500mm Frankenscope
Barlowed by 4x (I quickly "scaled" the image a bit!):
NO "Lunt 80" or "ED120 Quark"? But I'm still Excited!
If I can extend the focal length to 600mm... Just a
BIT more aperture... f/7 would give me 86.7mm! :cool:
At the moment I am pondering other and better(?)
Donor Scopes! I can extend my ersatz construction
method (and can afford) an ST120 OTA... Would it
be "good enough" re. Spherical Aberrations? What
if I stop it down to 90mm to match the ERF? etc.
I will also be limited to a Lunt BF600... I cannot
"Change the Laws of Physics", but maybe *bend*
them just a little? It's all "Light cones and Solar
Image diameters", right? [teasing] & <thinking> :lol:
Donor Scope suggestions are now very welcome!
Apologies for the extended <wibble>! Maybe this
might provide a similar *incentive* to others... :D
Macavity
Oh, I get it now!
Oh, I get it now!
Re: Frankencope Tests! (Apologies for absence)
Post by Macavity » Sat Oct 14, 2017 2:01 am
To complete this quickly and to answer a question from another thread!
(Adapted from other notes, so continuity / intelligibility not guaranteed!) :P
Since the above I bought an ST120 (to reclaim my ST102 grab & go OTA!)
The ST120 also maximizes the focal length for the Lunt BF600 and gives a
bit more "elbow room" for making "wood-technology" components! I have
also now finished an ERF cell and improved the "quick-release" clamping.
Without access to a lathe and requiring a quick & easy way of prototyping
I opted for the Hole Saw + "Redneck Lathe" (**) using MDF Lite (fibreboard).
To add a bit of accuracy I used the structurally firmer hardboard to make
the outer layer of what is (effectively) DIY plywood! :mrgreen:
** {Basically you make up a set of disks of appropriate outer diameter and
SPIN them using a power drill (in drill press) to fine tune outer diameters
using a file / sandpaper etc. N.B. Be careful applying lateral pressure to a
drill bit as this is not their intended purpose!! On the other hand MDF is
very soft? Do remember to wear a MASK to avoid breathing any MDF dust!} :shock:
It is usually necessary to make fairly exact diameter for the inner holes.
But, using the general method + a little imagination(?), you can make:
The Bung:
90mm Baader ERF Cell:
I found some PVC duct of larger diameter than the Refractor Dew Shield
and made the outer wall of the ERF cell by cutting /gluing TWO lengths
pipe around one another... You can also add ERF filter tilting etc. etc.
THE END result:
Collimation proved reassuring trivial! I just tried to square / shim the
OTA's as best as possible, using a engineer's square / digital level etc.
Focus is "restored" by sliding the Lunt OTA back and forth in the Frac!
I have included some *safety features*... A locking clamp and a BOLT.
I certainly don't want my Lunt 50 sliding onto the observatory floor!
Basically I am now operating the f/5 120mm ST120 at a stopped-down
86mm... To give the optimal f/7 light cone for the Lunt50 Etalon etc.
I suspect it may reduce e.g. spherical aberrations of an f/5 achromat?
I am not a particular master of Solar Processing, but I feel there is a
a significant increase of resolution in the approx 4x Barlowed images!
Native Lunt 50 (f=350mm):
Barlowed 86mm "Frankenscope" (f=1200mm):
For the moment I am happy enough with this. Clearly you can
"upgrade" it in a number of ways... Use a "better" objective...
Get a skilled machinist to make the components for you etc.
I part justify the cost of the ST120 by claiming I *needed* a
NEW and bigger ST120 Richest field (nighttime!) scope. But
that will be its main / alternative use in the quick release
scheme. The cost of a 90mm ERF was thus the "only" thing? :lol:
Post by marktownley » Mon Oct 16, 2017 8:10 pm
Looks really good!
