Omega CaK stack
Omega CaK stack
Post by Merlin66 » Sat Sep 23, 2017 12:46 am
The weather hasn't allowed me to test the Omega stack....
It's the <390nm UV block as a "mini erf", then the 80nm CaK followed by the 2A CaK.
Mounted on the TS102, Baader Herschel wedge (with 1.6ND filter).
Using the ASI 174MM.
(I've had to remove the tilter to gain focus...)
Well, today has thin high cloud, little wind, today's the day.....
Just collecting some AVI but visual on the screen looks promising. :cool:
Stay tuned!!!
Re: Omega CaK stack
Post by marktownley » Sat Sep 23, 2017 4:01 am
excellent!
Re: Omega CaK stack
Post by Merlin66 » Sat Sep 23, 2017 7:29 am
Quick run through AS3!, some Registax6 wavelets....
(What's the suggested/ recommended colouring??)
GUS
Re: Omega CaK stack
Post by GUS » Sat Sep 23, 2017 10:28 am
Great image Ken, visually the image is purple.
Re: Omega CaK stack
Post by Merlin66 » Sat Sep 23, 2017 11:16 am
Recommended RGB values???
Re: Omega CaK stack
Post by Merlin66 » Sat Sep 23, 2017 11:48 pm
Does this colouring look any good??
Re: Omega CaK stack
Post by Carbon60 » Sun Sep 24, 2017 6:16 am
Looking good, Ken.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
Re: Omega CaK stack
Post by marktownley » Sun Sep 24, 2017 7:49 am
Looking good Ken! Reading the setup (wedge and ND1.6) it sounds like you have a lot of light coming through (which isn't a bad thing!) - what sort of exposure are you at?
Re: Omega CaK stack
Post by Bob Yoesle » Sun Sep 24, 2017 1:58 pm
I have found this program is very useful for choosing RGB values:
http://www.efg2.com/Lab/ScienceAndEngin ... pectra.htm
Re: Omega CaK stack
Post by Merlin66 » Sun Sep 24, 2017 10:32 pm
Mark,
According to FireCapture log:
Shutter 35.71ms
Gain 257
Gama 39
Bob,
Thanks, I'll have a look.
