Lunt CaK B1800, inside visual inspection
allhoest
Post by allhoest » Mon Mar 12, 2018 8:38 pm
Hi!
I just bough a one of these CaK; here is the first inspection.
CS
Alex
The filter, side and top views
The diagonal assembly.
The allen heads are metric (!).
The screws were not tight fasten; some were even lose. Why? For any mirror compression issues? The mirror is fixed by some material, glue-foam probably. It can freely move, expand.
The diagonal itself is manufactured from a plain bloc.
My fear was that the mirror would be somehow treated, for dimmer reflection, like the blocking filters of coronado.
I have no real mean to measure the reflected flux, but while pointing the mirror toward the sun, plenty of light is reflected.
The front filter.
Sorry, I didn't feel the need to dismantle it…
The front assembly can be simply unscrewed. No need to take out the allen screws. It is a T2 thread.
The view to the intermediate filter shows some deposit on it. It looks terrible on the picture, because of the angle of view. But as we will see later, we can see something through it.
Finally, maybe I should dismantle these front assembly filters, for inspection.
The connecting part of the front assembly has an aperture of about 18mm
The rear assembly shows the 3rd filter, hidden behind the 1.25" adapter.
The thread is again the friendly T2
The view through the front assembly shows a purple cast, in accordance with the curve of these filters, posted on this forum
The picture is "quickly" taken with a smart phone.
The view through the rear assembly shows the famous yellow-green cast, in accordance with the description posted on this forum
For reference, here is a picture taken through a Baader K-Line
Strong prefiltrer, isn't it …
Re: Lunt CaK B1800, inside visual inspection
Post by marktownley » Mon Mar 12, 2018 9:00 pm
Thanks for the inside view Alex
allhoest
Post by allhoest » Sat Mar 31, 2018 9:15 pm
So, I gave a try with this CaK filter. I used a NP101 for this first light.
First, with no barlow, but then I had only phantom reflections:
Then I used a barlow. Results are here:
viewtopic.php?f=4&t=24259
CS
Alex
Charon_X
Post by Charon_X » Fri Apr 06, 2018 8:48 pm
The Lunt CaK module have a serial number ?
allhoest
Post by allhoest » Sun Apr 08, 2018 3:18 pm
There is no serial number on mine.
But as we know that there are variations in filter making process, that would be a good thing.
CS
Alex
TheSkyBurner
Post by TheSkyBurner » Sat May 26, 2018 1:22 pm
Allhoest can you repost the images of your lunt module onto this server so they dont get removed?
allhoest
Post by allhoest » Sat May 26, 2018 7:03 pm
Indeed, the picture are gone.
Here, I repost every description, one by one.
CS
Alex
20180303_008_Overview Top_enh.jpg (102.85 KiB) Viewed 424 times
20180303_001_Overview Left_enh.jpg (166.26 KiB) Viewed 424 times
allhoest
20180303_015_Diagonal Mirror_enh.jpg (209.78 KiB) Viewed 424 times
allhoest
Post by allhoest » Sat May 26, 2018 7:05 pm
20180303_022_Diagonal mirror reflection OK_enh.jpg (77.94 KiB) Viewed 424 times
20180303_021_Diagonal manufacture_enh.jpg (175.16 KiB) Viewed 424 times
allhoest
Post by allhoest » Sat May 26, 2018 7:06 pm
The front filter.
20180303_012_Front Filter_enh.jpg (106.48 KiB) Viewed 424 times
20180303_024_Fromt part assembly_enh.jpg (171.84 KiB) Viewed 424 times
allhoest
Post by allhoest » Sat May 26, 2018 7:08 pm
20180303_027_Intermediate filter_enh.jpg (90.55 KiB) Viewed 424 times
20180303_041_The aperture of the diagonal is ~18mm_enh.jpg (152.48 KiB) Viewed 424 times
allhoest
Post by allhoest » Sat May 26, 2018 7:09 pm
20180303_011_RearOuput & Filter - T2 therad + 1.25 adapter_enh.jpg (172.17 KiB) Viewed 423 times
allhoest
Post by allhoest » Sat May 26, 2018 7:11 pm
20180303_032_View through a Baader KLine_enh.jpg (58.9 KiB) Viewed 423 times
allhoest
Post by allhoest » Sat May 26, 2018 7:15 pm
20180303_037_View through the rear assembly_enh.jpg (135.89 KiB) Viewed 423 times
allhoest
Post by allhoest » Sat May 26, 2018 7:17 pm
2018May26 - Additional notes
I couldn't remove the adapter holding the 3rd filter.
Indeed, the parts connected to the diagonal look to be glued.
CS
Alex
allhoest
Post by allhoest » Sat May 26, 2018 7:18 pm
20180303_035__View through the front assembly_enh.jpg (98.92 KiB) Viewed 423 times
TheSkyBurner
Post by TheSkyBurner » Sat May 26, 2018 7:25 pm
thank you for the repost! very useful information here
