Lunt CaK Mod - Removing Etalon's adapter
allhoest
Post by allhoest » Thu May 24, 2018 5:58 pm
Hi!
I tried to get out of the diagonal the adapter holding the last filter (~Etalon).
I removed the hex screws on both sides (they are put back on the here picture, sorry).
Then I tried to get out this adapter, but it doesn't come out (It doesn't move at all...).
Has anyone removed it?
Is it glued?
I see on this adapter: three holes of ~2mm in diameter, located 120°.
One is marked with the arrow.
Do you have any idea for their use?
CS
Alex
allhoest
Re: Lunt CaK Mod - Removing Etalon's adapter
Post by allhoest » Sat May 26, 2018 5:40 pm
The 3 holes (one marked by the arrow) are not deep enough to come to the delrin ring.
These holes are approx. 3mm in depth.
The holding ring is maintained by a little strap of glue or silicon.
allhoest
Post by allhoest » Sat May 26, 2018 5:43 pm
I was following this post:
viewtopic.php?f=9&t=12203
and more especially this image from this post, where the part connecting to the diagonal was disassembled:
I gave a try again to remove the etalon holding adapter out of the diagonal, but it is extremely firmly fixed. It is maybe glued.
PS: I'll upload again the pictures of the former post related the to inside inspection of the filter.
CS
Alex
allhoest
Post by allhoest » Sat May 26, 2018 6:46 pm
I opened again the diagonal and had a closer look.
Indeed there are 2 white straps of something very much looking like glue.
:evil:
CS
Alex
