66245 Heatsink mirror mount for 81045
Re: 66245 Heatsink mirror mount for 81045
Post by MalVeauX » Fri Jun 15, 2018 1:59 pm
So basically this is a UV Wedge?
Yikes on those prices. ~$800 USD. Can get a Lunt module for this. I'm curious about a comparison to see if it's worth while (especially if it allows use of a large aperture instrument, over 4 inches).
Post by Valery » Fri Jun 15, 2018 3:31 pm
For about the same money you can order a front mounted 145mm two bands (both Calzium K and H and H-a) DERF filter!
Users browsing this forum: AndiesHandyHandies and 1 guest
