Narrowest 393.37 ever by Apollo Lasky
Re: Narrowest 393.37 ever by Apollo Lasky
Post by bart1805 » Thu Oct 11, 2018 8:16 pm
Found this information about a UV-Barlow lens.
https://www.astrosystems.nl/uv-barlow-
TheSkyBurner
Post by TheSkyBurner » Wed Oct 17, 2018 1:41 am
Very nice, too bad it costs $800 to build it. :(
Uv lenses are not cheap.
I did happen to figure out a solution as well, and mine costs 1/10th as much and works with all telescopes. Not just that one sct..
(i just re-read that document, and the guy made an entirely new corrector lens for his sct. So that barlow will be questionable for comparative sct results..)
krakatoa1883
Post by krakatoa1883 » Wed Oct 17, 2018 11:49 am
As a starting point it would be enough to use a barlow fully transparent to the UV. At slow focal ratios even a single long focal lens would work fine
while for fast f/ratios a singlet would not be enough due to increasing spherical aberration. Of course if one needs a telecentric system things become more complicated anyway.
My personal page on Google+
My personal web site on practical astronomy and astronomical optics
Post by marktownley » Wed Oct 17, 2018 12:38 pm
Good point Raf. What lens is that one you used?
krakatoa1883
Post by krakatoa1883 » Wed Oct 17, 2018 2:30 pm
This one from Edmund Optics
https://www.edmundoptics.eu/p/25mm-dia- ... lens/8568/
it was just an experiment but gone very successful. One can obtain even better results by a plano-concave (instead of a double-concave) lens provided with a UV-AR coating that covers 250 to 425nm, the price difference is small and worth the extra money.
Lenses can then be easily mounted in T threaded barrels
https://www.edmundoptics.eu/p/25254mm-d ... unt/10576/
Post by marktownley » Wed Oct 17, 2018 7:18 pm
Very interesting Raf, which is the plano concave lens you tried?
krakatoa1883
Post by krakatoa1883 » Thu Oct 18, 2018 7:08 am
This is the page
https://www.edmundoptics.eu/p/250mm-dia ... lens/8557/
look under Technical Images in that same page for further information on how the lens works.
Choose the focal length based on the amplification you wish to obtain, ideal would be a long f.l. lens (say 100 mm) as this helps to contain aberrations, however if you have to amplify much (3x - 4x) a long f.l. would lead to a cumbersome (very long) optical train. The slower the scope the better the performance, no good with my newtonian at f/5, for example, much better at f/10 or slower.
highfnum
Post by highfnum » Mon Oct 29, 2018 3:11 am
very interesting!
highfnum
Post by highfnum » Tue Oct 30, 2018 4:35 pm
i sent email to chroma
no response
highfnum
Post by highfnum » Sun Nov 04, 2018 7:30 pm
sent e-mail over a week never got an answer back
TheSkyBurner
Post by TheSkyBurner » Sun Nov 04, 2018 8:01 pm
they wont respond, because I canceled the project. Sorry!
