another PST stage 2 mod
Re: another PST stage 2 mod
Post by marktownley » Wed Aug 15, 2018 12:01 pm
Nice!
bart1805
Post by bart1805 » Thu Aug 16, 2018 8:15 pm
Beautiful telescopes Pedro! Are you going to use the etalon in the f/7 beam? You could maybe try a Baader 1,7 Glasspath. Would give f/11,9.
pedro
Post by pedro » Thu Aug 16, 2018 8:55 pm
I also bought a Baader 1.25X Glasspath (it's on the way)
bart1805
Post by bart1805 » Thu Aug 16, 2018 9:32 pm
The Glasspath works perfectly. Got the idea from banjo on this forum and use it myself in a 150mm f/8 Skywatcher. Mounted the Glasspath in the nosepiece.
Post by Carbon60 » Fri Aug 17, 2018 5:53 am
Looking forward to seeing images from this mod, Pedro.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
pedro
Post by pedro » Fri Aug 17, 2018 10:30 am
Thanks Stu
It works but it will be better after I install the Baader 1.25X glasspath, I will you keep you guys posted
pedro
Post by pedro » Tue Aug 28, 2018 4:28 pm
I finally have all the pieces for my PST Satge 2 MOD. I received the Baader 1.25X Glasspath Corrector yesterday. I plan to use it maily with two telescopes> TMB100 F/8 and TEC140 F/7. Check out some images from my FLICKR page
ImagePST_STAGE_2_MOD_20180828-27 by Pedro Ré, on Flickr
BAADER 110mm ERF + Teflon Adapter + PST etalon and adapter
ImagePST_STAGE_2_MOD_20180828-13 by Pedro Ré, on Flickr
ImagePST_STAGE_2_MOD_20180828-12 by Pedro Ré, on Flickr
ImagePST_STAGE_2_MOD_20180828-10 by Pedro Ré, on Flickr
ImagePST_STAGE_2_MOD_20180828-07 by Pedro Ré, on Flickr
ImagePST_STAGE_2_MOD_20180828-05 by Pedro Ré, on Flickr
ImagePST_STAGE_2_MOD_20180828-03 by Pedro Ré, on Flickr
ImagePST_STAGE_2_MOD_20180828-17 by Pedro Ré, on Flickr
ImagePST_STAGE_2_MOD_20180828-19 by Pedro Ré, on Flickr
ImagePST_STAGE_2_MOD_20180828-21 by Pedro Ré, on Flickr
bart1805
Post by bart1805 » Tue Aug 28, 2018 4:46 pm
Nice! And now waiting for the first pictures. (-;
How did you mount the glasspath on the front lens? Ans I am curious if the distance between the back of the etalon and the focal point is about 20 cm, looks shorter. Or did you change the lens?
pedro
Post by pedro » Tue Aug 28, 2018 6:09 pm
Thanks Bart
It's cloudy here but it will improve in a couple of days. I had to use a plastic spacer to fit the glasspath in front of the etalon. I cannot use a long distance after the PST etalon, otherwise I will not get my camera in focus. I will give it a go and let you know.
bart1805
Post by bart1805 » Tue Aug 28, 2018 6:47 pm
Interesting, I thought it was not possible so had it mounted in the nosepiece. But you still have the original front lens before the etalon?
Maybe the fact that you could not reach focus had something to do with the backfocus of the scope and the fact that you worked in a f/8 beam.
pedro
Post by pedro » Tue Aug 28, 2018 8:10 pm
I did not try yet the mod with the Baader Glasspath in front of the etalon. I could reach focus without it
Where exactly did you mount the glasspath? Inside the nosepiece?
Mine is close to the etalon also inside the nosepiece
bart1805
Post by bart1805 » Tue Aug 28, 2018 8:43 pm
Hi Pedro,
Yes inside the nosepiece. I got the idea from banjo, in this thread there is also a drawing of his nosepiece. viewtopic.php?f=4&t=23610&p=212934&hili ... th#p212934
AOK made a nosepiece for me and mounted the glass path.
CS Bart.
pedro
Post by pedro » Wed Aug 29, 2018 12:42 pm
Tried the PST Stage 2 Mod today for the first time (TMB100 F/8). Visually it is great. For imaging it is not the same thing, big soft spot
Check out some images below.
More in a different thread
pedro
Post by pedro » Wed Aug 29, 2018 1:35 pm
First light (TMB100 F/8 + PST Stage 2 Mod, X2 Barlow @X1.4)
more at: viewtopic.php?f=4&t=25032
