baader planetarium 36mm unmounted filters
TheSkyBurner
Post by TheSkyBurner » Sun Aug 26, 2018 11:04 pm
The baader planetarium 36mm filters are unmounted, but you can mount them incredibly easy.
example below.
First you need a filter cell,
This one works perfect. https://www.ebay.com/itm/Zeikos-ZE-UV37 ... 2749.l2649
Remove the glass from the 37mm zeikos filter, pop in the 36mm baader planetarium filter and attach the double male 37-46 thread adapter, this leaves room for the glass to expand just like baader planetarium.
The double male coupling ring replaces the retainer ring flawlessly.
https://www.ebay.com/itm/37-46-Double-M ... 2749.l2649
Since there are now male 46mm threads you must attach a 48 to 46mm adapter. With these two filter rings you can now thread this component on a 2" nose piece or barrel as normal and save a few bux over the 48mm baader planetarium filters.
https://www.ebay.com/itm/48mm-46mm-48mm ... xy2YtRra5b
