New Lunt Mod
New Lunt Mod
Post by MapleRidge » Fri Oct 05, 2018 4:47 pm
Hi everyone...
A quick post about a revision I made to my modded Celestron CR-150 OTA/Lunt DSII etalon mod.
I have been wanting to set up a double stack on this system but never had a lot of time to pursue it...had been thinking of trying a Quark but wasn't prepared to shell out the cash without knowing if it would work.
What I wound up doing was hiving a local machinist make a threaded adapter to allow mw to mount the primary Etalon out of my LS80T at the rear of the donor OTA, and then install the DSII module for a DS system. I had a very short window to assemble and test yesterday over the noon hour...terrible seeing and strong winds made for an interesting first light.
The layout is shown below...from right to left: CR-150 OTA (internal Baader ERF)/Primary LS80T Etalon (red)/DSII module (black)/Moonlite focuser/B1800Ha blocking filter/Explore Scientific 3x Tele-converter/Daystar tilt adapter mounted to the ZWO ASI174MM camera:
First are a few images in the single stack mode:
In the DS mode it does improve the contrast:
Just a few points on the images...no flats (some dark banding in the DS images) and no alignment checks due to time limits. I just assembled the pieces and shot the test frames before I ran out of time. To seal the trial off I had clouds roll in until I was back to the office :o
Waiting on another sunny day to test things out some more.
Questions and comments are welcome...how do the modders in the group see this???
Another pending Mod is to fit the DSII to the C9.25 Edge as a single stack. A trial looked promising but my temporary housing wasn't rigid enough to stop the flexure. I'd like the ability to run this and use the pressure tuning to do quick on-band/wing images and when the seeing is good switch to the Quantum for the more narrow bandpass work (0.45A).
krakatoa1883
Re: New Lunt Mod
Post by krakatoa1883 » Fri Oct 05, 2018 5:28 pm
Nice setup Brian, it seems working really fine. I don't have a DS module for my Lunt mod however my Quark increases contrast dramatically compared to the SS.
Just a question: does the ES 3x work as a telecentric amplifier ?
Re: New Lunt Mod
Post by MapleRidge » Fri Oct 05, 2018 6:22 pm
Hi Raf...
Thanks for the feedback on the setup. I hate to keep the LS80 in pieces and it does such a nice job on full disk images. I had been thinking of trying a Quark without the built in barlow as a DS unit (the photoshereic one might work ok as I'm not trying to beat the Quantum) but I don't have one to experiment with.
The ES tele-extenders are relatively telecentric...I've used them for years and seem to work as well as the Powermates. Teleview doesn't have the 3x, and these fit my budget a bit better too :)
krakatoa1883
Re: New Lunt Mod
Post by krakatoa1883 » Fri Oct 05, 2018 7:38 pm
Thank you for the info, I am planning to purchase a 3x amplifier because my Powermate loses amplification with the distance from the lenses. Best would be a Baader TZ system but it costs much more.
Re: New Lunt Mod
Post by MapleRidge » Fri Oct 05, 2018 7:58 pm
Raf...
I see that Explore Scientific has just introduced a 2"version of the 3x extender. It isn't as much an issue with the Ha system (1.25" blocking filter), but I prefer to reduce as many adapters (2"-1.25") as I can to keep the collection of optics as well aligned as I can. If it will fit ahead of the blocking filter that might help, as opposed to putting the extender between the camera and blocker.
It will be a good option to use with the WL and CaK filters since they are 2" and I could get rid of the reducers.
Re: New Lunt Mod
Post by bart1805 » Fri Oct 05, 2018 8:38 pm
Wow Raf, that looks great! Congratulations!
No double limb at all anymore with the DS.
Re: New Lunt Mod
Post by Carbon60 » Sat Oct 06, 2018 8:23 am
Looks like an excellent setup, Brian, producing very nice first light images, right off the bat.
I looks highly promising for the new season in spring ;)
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
krakatoa1883
Re: New Lunt Mod
Post by krakatoa1883 » Sat Oct 06, 2018 9:21 am
they're Brian images, Bart ;)
Brian, are you using the extender for extracting the focus or just to enlarge the image ? In my Lunt mod I barely reach focus with my Chameleon so I inserted a Powermate between the focuser and blocking filter.
Re: New Lunt Mod
Post by marktownley » Sat Oct 06, 2018 9:34 am
Looks like the mod works well.
Re: New Lunt Mod
Post by MapleRidge » Sat Oct 06, 2018 3:29 pm
Bart, Stu, Raf, and Derek...
Thanks for all the feedback on the setup. Cloudy/rainy Thanksgiving holiday weekend has set in here, so more testes will have to wait. Maybe a nice big AR will appear next week to use as a test subject ;)
Raf, I use the extender to bump the focal length/image scale. I also have an Airylab 2.7x telecentric to try as well, though I need to find some adapters to fit it into the system since it has all threaded connections.
Users browsing this forum: No registered users and 5 guests
