Mersenne telescope design
bandazar
Post by bandazar » Wed Oct 10, 2018 5:56 am
I've been thinking about this combination in my head. Would a Mersenne telescope in front with a h-alpha scope in the back attached achieve a higher resolution? Or would it be similar to just having an h-alpha telescope with an ERF that does not block as much energy allowing in more light?
Re: Mersenne telescope design
Post by Bob Yoesle » Thu Oct 11, 2018 9:01 am
I have considered this as well. There is a good discussion on the Mersenne design here:
https://www.cloudynights.com/topic/3922 ... telescope/
There is significant potential field angle magnification and greatly exacerbated off-axis aberrations due to the secondary objective's inability to perform optimally with the magnified field angles. Therefore the Mersenne likely would be useful only for narrow fields of view.
Users browsing this forum: Google [Bot] and 2 guests
