Adapter for doublestacking PST etalons
Hi everybody,
Ken asked me a question about my 3D printed adaptor to doublestack two PST etalons. It was a succes as far as printing M50x1 was concerned. But when I used the adaptor you could see extreme banding in the images.
The 3D printed adaptor looked like this:
The adaptor before sanding by bart moors, on Flickr
And here you can see the banding:
040917_10.21_BR127_DS_PM2,5x_AR2673 by bart moors, on Flickr
After that I asked Beat (AOK) to make me an adaptor. He made one and it worked almost the same as the 3D printed one: a lot of banding. The big advantage of the AOK adapter is that you can "radially tune" the adaptors, but the banding was still there. The wisdom of the forum told me to use a Circular Polarizer. Unfortunately with a CP mounted inside the adaptor, it was a bit short. So I also needed the 3D printed adapter. With a bit of tape and a piece of a toothpick I could hold the CP at its place. This was a succes!
Here are some pictures of the AOK adapter:
20190118_140237_resized by bart moors, on Flickr
20190118_140245_resized by bart moors, on Flickr
20190118_140302_resized by bart moors, on Flickr
And here is how it looks when the two PDT etalons are doublestacked. Front one without backlens, the other one without the frontlens.
20190118_140742_resized by bart moors, on Flickr
From right to left:
Etalon B
3D printed adaptor
AOK doublestack adapter
Etalon A
AOK adaptor to mount the etalon in a SCT focuser.
And two DS pictures:
24092017_14h58m_Br127_DS_PM2,5x_AR_PSV2 by bart moors, on Flickr
230917_14h07m_Br127_DS_PM2,5x_AR_PS_Inverted by bart moors, on Flickr
It would be perfect if you could rotate the CP while maintaining the alignment and orientation of the etalons. Ken suggested the following:
Two side access holes/ slots and using a smaller internal filter thread (37mm CPL diameter?) in the adaptor. The outer edge of the rotating filter could be accessed through the side slots. I just thought of another problem because you have to mount the adaptor "the other way around".
Has anyone got another idea how this could be realised? Or an idea for the ultimate 2.0 version?
And is anybody interested in this adapter? If so I can ask Beat to make a price for a couple of these adaptors. Ken and I will both order one if the price is decent. No meaning to earn anything out of it, you pay what Beat asks. If it would cut the costs any further I can pay for all the adaptors and ask Beat to ship the adaptors to me so I can ship them from the Netherlands all over the world. My original AOK adaptor costed CHF 60,--. So that is about $61,--. Honestly don't know what the 2.0 version would cost. I will let you know if you are interested.
CS!
Bart.
From right to left:
Etalon B
3D printed adaptor
Etalon A
CS!
Bart.
- Has thanked: 1192 times
- Been thanked: 1387 times
Re: Adapter for doublestacking PST etalons
Very interesting, I certainly would be interested and to see how this develops and would probably buy too!
This would probably be the best candidate to serve as the 37mm CP:
https://www.ebay.com/itm/B-W-37mm-XS-PR ... :rk:9:pf:0
And the possibility to rotate the CP 90 degrees seems to be sufficient?
- Has thanked: 20834 times
- Been thanked: 10502 times
Nice adapter Bart
Two ideas for the Circular Polarizer. The first one is from Apollo.
https://www.bhphotovideo.com/c/product/ ... izing.html
https://www.teleskop-express.de/shop/pr ... esign.html
The latter one is a whole lot cheaper and pretty simple. On the front:
Nosepiece with M50x1 female, back male M48. 2,5 to 3 cm long.
On the back:
M48 female adapter to M50x1 male including the ring to radially tune the etalons. Length about 3 cm.
Total length would be about 7,5 to 8 cm. That is the same as the AOK adapter plus the 3D printed adapter plus the optical path of the filter changer. And off course would need a ring to mount the current 46 mm polariser in the filter drawer.
If everything is mounted it is easy to take the filter drawer out to twist the polariser.
On the back:
Bart,
I have a set of the Neumann filter drawers. Could use a standard 1.25” CPL filter.
Just needs a couple of T thread to M50 Adaptors?
I think you are right Ken. I would like to use the B+W circular polarizer because it has a high transmission (the filter has to be placed backwards btw).
Plus the back adapter needs the extra ring so you can position the back etalon to the front etalon and hold it that way. So the shopping list would be:
1) A filter drawer
2) Front adaptor, relatively simple. M50x1 female at the front. Thread to the drawer at the back.
3) Back adapter with the extra ring to hold the etalon in the position you want it to be. Front is thread to drawer. Back is M50x1 male
4) CPL and possibly a retaining ring to mount the CPL in the filter drawer.
1) A filter drawer
Yeah, that sounds about right!
This could be another possibility to rotate the CP.
Two of these, in between them a short T2 extension with the CP mounted inside.
https://www.teleskop-express.de/shop/pr ... short.html
Bart,
We have used these T2 rotators for some years on the spectroscopes - work well...
You can also get a T thread to 1.25" filter thread adaptor ......
Hi Ken,
Nice! And can they handle the load? In my case there is quite a lot of weight hanging after the etalon because a JMI focuser is included.
I asked Gerd Neumann if he is able to produce his filter drawer with different threads on the front and back. Is is in your mail too.
- on the front side 21 mm M50x1 female
- on the back side 20 mm M50x1 male.
- plus a ring about 7mm thick, 7cm high with M50x1 female on the inside. The ring is needed so you can clock the two etalons against each other and retain the ideal position.
CS! Bart.
ps. Maybe it is also time to get rid of the focuser in the imaging train and go for a simple 20cm distance from the last etalon to the camera.
CS! Bart.
Bart,
The T rotator was holding the ATiK 314 camera on the rear of the spectrograph...no issues.
I'm using a short Lunt Crayford focuser on the SM60/ED80/PST mod DS - I find it very useful, when changing cameras and or barlows etc.
You are right Ken, it is useful. The JMI weighs about 600 - 700 grams I think.
The ATiK 314L is 400gms.
Gerd Neumann responded that he is able to make the adaptors for a standard filter drawer and is able to make a drawer with the M50x1 threads on the front and back. Will make some drawings and send these to him.
Apollo is working on another solution, based on a dovetail concept. Very interesting too!
