I now can use some bits for a 12" dobsonian.
I lent the mirror to someone and they cleaned it without asking and took half the aluminium off!
'Home' aluminised at my first club and some pre-cleaning artefact in the coating it looked like.
So might as well take it all off.
Whats the best narrow band filter (s) to use?
Rod points out he used a 10" Newtonian for solar projection for hours with no issues.
Andrew
12" White light Newtonian
- Has thanked: 3321 times
- Been thanked: 1907 times
- Has thanked: 1192 times
- Been thanked: 1387 times
Re: 12" White light Newtonian
Well, use a 656nm (Astronomik HA 12nm) filter for poor seeing.
Use a 395nm or 430nm (Andover or Edmund Optics) for higher angular resolution with very good seeing.
- Has thanked: 20834 times
- Been thanked: 10502 times
Depends how much light you want coming through
Yep, you are absolutely right!
- Has thanked: 714 times
"Don't forget to de-aluminise the secondary mirror!"
If you do so, you will have a very strong filtering.
Maybe you want it that way, but keep in mind that you will have to collimate it!
- Been thanked: 2725 times
As said by Alexandre, just keep the primary uncoated and the secondary coated.
Regarding filters, it all depends on the seeing conditions at your place. A 300 mm is a bit of a large telescope for solar image.
The range of usual filters are :
- deep-sky Ha, when seeing is bad,
- 540 nm, when seeing is good,
- deep-sky OIII, when seeing is pretty good,
- 430 nm, when seeing is excellent,
- 396 nm, when seeing is perfect.
