"Magic" distance of Lunt LS50PT etalon from focal plane?
Hi everyone!
After building several PST mods years ago (with great help from this forum), I recently aquired a used Lunt LS50T B600. It appears to outperfom my old PST, and I'm thinking of making a stage 1 mod using this Lunt. Visual use only BTW.
I have a 75mm front ERF, so a 70mm f=500mm (f/7.14) donor scope should be the way to go. At least not much bigger considering the size of the B600.
The only thing I'm not able to get confirmed is the required distance of the etalon unit from the focal plane. In the PST this was quite critital.
Any thoughts?
Any thoughts?
- Has thanked: 2882 times
- Been thanked: 1162 times
Re: "Magic" distance of Lunt LS50PT etalon from focal plane?
Yes, it's 140mm (20mm x 7). Good luck with the mod.
Ah great! I guess that's the diameter of the etalon x the focal ratio of the objective - makes sense.
That 140mm is measured from the focal plane to which part of the etalon unit?
To the back of the unit, so the back lens.
Thanks!
Still one thing I was wondering: I understand that the little correction lenses bring a f/7 tot parallel, and after the etalon back to f/7 again. What exactly is the effect of increasing the focal ratio on the image? Let's say I would like to use a f/7,5 objectieve instead of an f/7.
If this has no effect on the performance of the etalon, it might be possible to move the etalon unit a little bit further up the tube, before it will vignet the light cone. This can be useful to fit a more decent focuser behind the unit and reach focus. However, if this is uncharted territory, I'll stick to f/7 just to be sure...
I'd say the front lens Bart, but sat here reflecting on it all with my coffee this sunday morning, I think there is a valid discussion for both our answers
The front lens needs to be -140mm ahead of the focal point so it intercepts the converging beam where it is 20mm in diameter, this is because the etalon has free diameter of 20mm, and we want to maximise our etalon surface area usage- this is what costs the $$$. The collimated beam that passes through it is 20mm in diameter, and then the rear, re-converging lens, then turns this back into a converging beam with a focal length of 140mm from the back of this lens. The front collimating lens and rear re-converging lens both have a focal ratio of f7 so any aberrations created are cancelled out.
It will work if you use the back of the unit for the -140mm marker distance, however the diameter of the converging beam passing through the front collimating lens will be greater than 20mm, so the housing of the lens cell will act as a field stop on the etalon, resulting in a smaller exit pupil diameter than you could potentially have using the logic above. Effectively, you're now running at a back focus distance of 140mm + thickness of red etalon housing (maybe closer to 200mm? - don't have my LS50 handy). This might not be an issue as the field you would be losing could be outside the jacquinot (sweet spot)) diameter, and, so, might not be usable field anyway. ???
So, simple answer, the distance is a starting point, work with that initially and tweak with what works best as you become more experienced using the system. If you're running a f7.5 system, the numbers will be slightly different, but go with the above in the first instance and refine as you go along.
- GreatAttractor
- Has thanked: 124 times
- Been thanked: 31 times
I suggest you measure it precisely yourself. Here's a simple method I used: viewtopic.php?f=9&t=19238
My software:
My images
My images
Forgot about this thread! Nice contribution to the discussion.GreatAttractor wrote: ↑Sun Nov 24, 2019 9:22 amI suggest you measure it precisely yourself. Here's a simple method I used: viewtopic.php?f=9&t=19238
Interesting Mark! In my opinion you should start with the putting the front lens at minus 140mm. Then there is the etalon, the new focal point is at 140mm behind the back of the etalon. What I mean is that both distances should be 140mm, starting with the front.marktownley wrote: ↑Sun Nov 24, 2019 9:10 amI'd say the front lens Bart, but sat here reflecting on it all with my coffee this sunday morning, I think there is a valid discussion for both our answers
I suppose we should define front and back too - my 'front' would be objective side, my back would be etalon side
We agree. (-;marktownley wrote: ↑Sun Nov 24, 2019 11:07 amI suppose we should define front and back too - my 'front' would be objective side, my back would be etalon side![]()
- Has thanked: 31 times
- Been thanked: 111 times
I have heard that etalon diameter in this telescope is 26mm, not 20mm.
This afternoon I totally took apart my 50mm Lunt. I took several measurement, some of them did not match up the specification mentioned above. Some remarkable findings about possible vignetting also... I will post the results in another topic this evening, while it might be interesting for al who want to mod their LS50T.
I've been thinking about this for a while now, and I'm not quite sure it's that simple. While it seems logical, the original Lunt 50mm is not built that way: the first collimating lens is at 168mm inside focus. While the objective is an f/7.14 it "should" be at -143mm.
I believe we can pretty much assume Lunt designed the first collimating lens to get the beams of the objective parallel through the etalon. That means that even when using a longer focal ratio objective (f/7,5 or f/10), the first lens always has to be at -168mm to get that parallel beam. When you move the position of the etalon box, you might get the most light through the etalon, but you change the angle of the light beams hitting the first lens, resulting in a non-parallel beam.
I made a small drawing to explain what I mean. Taking 2 equal diameter objectives with different focal ratio's, the optimal position of the fist collimating lenses (considering illumination) are at different positions: with f/10 farther back than with f/7. But then the incoming angles (especially at the edge of the collimating lens) changes as you move its position, resulting in a non-parallel beam.
I believe the angle of the incoming beam is more crucial to the working of the etalon than optimal illumination. I think sticking to Lunt's -168mm rather than the calculated -150mm position for my f/7,5 mod might be the best choice. Still 18mm difference between outcomes is quite a lot, and I can only cut the tube once...
Any thoughts on this?
- 20191203_113334_resized.jpg (244.32 KiB) Viewed 3558 times
Slow on the reply here sorry!
If the objective is f7.14 (and I don't doubt that!) then yes, for the etalon enclosure (20mm opening) to be not operating as a field stop then the distance is -143mm.
If the etalon enclosure is sat at -168mm (25mm further in than -143mm), then it is doing this to act as a field stop. This is to reduce the maximum field of view of the scope. A 50/350 has about a maximum fov of about 4 degrees, this is not necessary with the sun only having an angular diameter of half a degree.
The collimating lens in the etalon assembly turns that converging beam from the objective in a (parallel) collimated beam. The 'strength' of this collimated lens will be matched to a particular focal ratio of objective lens, changing that focal ratio will result in a less than perfect collimated beam - ie you might get a somewhat diverging beam passing through the etalon, or, a very high focal ratio still converging beam. Either of these would result in a smaller sweetspot than with an etalon that operates in a true collimated beam. The larger the sweetspot the larger the usable field of view.
Not sure what focuser you use with your f7.5 scope, but if it has an m68 fitting you can always add extension tubes to it to get the etalon further out, cutting 'short' isn't necessarily a bad thing.
marktownley wrote: ↑Mon Dec 09, 2019 10:05 pmThe 'strength' of this collimated lens will be matched to a particular focal ratio of objective lens, changing that focal ratio will result in a less than perfect collimated beam - ie you might get a somewhat diverging beam passing through the etalon, or, a very high focal ratio still converging beam. Either of these would result in a smaller sweetspot than with an etalon that operates in a true collimated beam.
Let's assume the configuration of the original Lunt LS50 is ideal given the parts' dimensions. (Which I think is true, considering the nice big sweet spot. I'ts larger than the sun's diameter at f=350mm).
Obviously a parallel beam is more important for optical perfomance than the amount of vignetting.
So I also think the original -168mm for the first collimating lens is to be used in all mods from f/7 and longer. It is the only position where that lens diverges a incoming beam to parallel. To be sure I'm going to make a sketch of what I mean, but for now I believe that for example an f/12 cone can still be collimated to parallel, but only when it's placed at -168mm.
- Oh, I get it now!
- Been thanked: 2 times
Guys, resurrecting the old thread ..
I did some mods to my lunt 50, a few years back: viewtopic.php?f=9&t=22934&p=208244#p208244
On of them is pairing it to a 80mm F7.5 refractor.
Now, I have a dead daystar quark, to experiment with. Pulled out the telecentric barlow, out of it and paired it to my lunt50, eliminating the B600 diagonal:
From the brief tests (monsoon season here), I could fit the full disc in view, with the Canon 450D camera, as well as using 40mm eyepiece and a regular mirror diagonal, for visual.
Now, I really wanna pair it with the 80mm refractor I have and get the full use of the larger bf of the daystar quark.
I'm lost with calculating the ideal distance, from the 80mm refractor's objective, to the lunt's ethalon, to get the sweet spot right, for this combo.
Any input very welcome!
- Bob Yoesle
- Has thanked: 5 times
- Been thanked: 55 times
There is no "magic distance." There is a very real correct distance.
This distance for the negative collimator is for it to lie towards the objective the exact focal length of the collimator lens from the objective's focal plane. With a negative lens, the focal length is more difficult to determine than for a positive lens like the objective. But you have the ability to reliably know what this distance is by removing the collimator module and measuring where the objective's image of the Sun (or other object at infinity) falls. This is the focal plane of the objective. Then measure how far ahead of the objective focal plane the collimator lens would be when the telescope is correctly assembled. This should be the focal length of the collimator lens.
Then no matter what the particular objective or its focal length, the collimator lens should lie this far ahead of the objective's focal plane in order to produce a collimated bundle of axial rays to the etalon.
"The collimating lens in the etalon assembly turns that converging beam from the objective in a (parallel) collimated beam. The 'strength' of this collimated lens will be matched to a particular focal ratio of objective lens, changing that focal ratio will result in a less than perfect collimated beam - ie you might get a somewhat diverging beam passing through the etalon, or, a very high focal ratio still converging beam. Either of these would result in a smaller sweetspot than with an etalon that operates in a true collimated beam."
Hi Mark,
The amount of field angle magnification (FL obj / FL col, aka "strength") is what determines the size of the Jacquinot spot (e.g. "sweet spot" diameter). If the focus of the collimator lens is not coincident with the objective's focal plane, the system can not produce axially collimated light (it is impossible to collimate the off-axis field angels). It has nothing to do with the focal ratios.
Differing focal ratio's between the objective and collimator will not alter the field angle magnification, but potentially may change the amount of illumination of the image - which is the amount - if any - of vignetting. Vignetting effects and the Jacquinot spot diameter are not the same - field angle magnification is independent of the focal ratio's, and completely dependent on the objective and collimator lens focal lengths and positioning.
Hi Mark,
