So I've tried to use both my 200mm F6 Quartz newtonian (quartz primary & secondary) with my full aperture D-ERF as well as my 200mm F10 SCT with the same D-ERF. I got the newtonian because it's F6 quartz mirror would be better for short wavelength imaging (gband, calcium) compared to the SCT mirror (F2~F2.2) which has significant issues at short wavelength at full aperture. I ran into something interesting though. The D-ERF on my SCT handles heat fine. The image is steady. No signals saying there's something getting too hot in the optical train or in the tube itself. And to my "hand test" there's no heat coming out when I combine the full aperture D-ERF and then a Baader Red CCD-IR block (50mm) filter right before the imaging train as the 2nd D-ERF. Handles heat great in the SCT. But this is not the case with the 200mm F6 Newtonian! The heat is not handled right, something is getting too hot I think. With the full aperture D-ERF over the 200mm aperture newtonian, there's a weird nervous bend or spasm effect noted in the image (and its not the seeing), no matter what and it makes it impossible to get good focus and image. I wonder if it's the secondary mirror getting hot being so close to the aperture of the scope and getting light from both sides? The heat coming out of the focuser is also significantly higher than my SCT, even with a 2nd DERF there, it's hotter on my hand and melts things at the point of focus. Any ideas why the newtonian with the same DERF setup cannot handle the heat, but the SCT can? I would think the newt would be better for heat being an open tube unlike the sealed nature of the SCT?
Not sure how to fully thermally regulate the newtonian (with fully aluminized mirrors) with D-ERF's. I woudn't think the issue is the primary mirror. I would think maybe it has something to do with the secondary mirror? But then I think of SCT and how does it handle it on its secondary mirror?
Thoughts?
Example of the nervous twitch with the newtonian. The seeing was good, so it wasn't that. If seeing was poor the features would be out of focus and blurry. Instead, they all have a movement to them, a nervous twitch, that happens faster than seeing changes and isn't frozen via camera at short duration exposure. It's almost like a guasian motion blur applied. Because of this I stopped using this scope for solar. This was with both D-ERFs in place (full aperture front, and internal before the imaging train).
