Coronado/Lunt hybrid?
hopskipson
Has thanked: 4 times
Been thanked: 3 times
Post by hopskipson » Thu Feb 13, 2020 2:55 am
Hi All
I’m thinking of double stacking my LS60 pt, but don’t want to shell out $1500 for the Lunt 60mm DS filter. Has anyone tried to use the solarmax 2 DS filter instead? Seems like a cheaper option even with a precise parts adapter. Please let me know if this will work or am I better off sticking with Lunt. Thanks!
Has thanked: 1323 times
Been thanked: 545 times
Re: Coronado/Lunt hybrid?
Post by marktownley » Thu Feb 13, 2020 6:57 am
Yes, will work in theory. But only as effective as stacking Lunt Lunt or Coronado Coronado. Regardless of permutation, the etalon with that needs the most tilt needs to be the outer etalon in the system.
hopskipson
Post by hopskipson » Thu Feb 13, 2020 11:56 am
I'm a little confused, most of my solar has been with a Quark. I just recently purchased a Pressure tuned Lunt 60. So this should work (in theory) or do I need to do something else to make it work? Or is sticking with the Lunt my best bet? I realize the DS etalon will need some tilt to get on band and move the ghost image, will I have enough tilt using the Coronado to do so?
Sorry for my ignorance :cat
Post by marktownley » Thu Feb 13, 2020 1:18 pm
In theory it should all work! Etalon combinations are fickle things mixing and matching. My advice, try before you buy. If unsure buy the Lunt double stack, I know it cost's more but you can return if not good. Stacking a Coronado onto a Lunt should work but if it doesn't are Coronado going to accept a return?
hopskipson
Post by hopskipson » Thu Feb 13, 2020 10:49 pm
Point taken!
Thanks Mark.
