Hello guys,
Thanks with all your help so far. If I were to use the PST mod on the TEC140 what else would I need? I know that it should be used on an F10 scope and the TEC140 is F7. I already have a front ERF at 125cm from my Quark days, so I think this makes the TEC140 F7.84 with this ERF.
To make it F10 before the PST mod I would a need a 1.3x telecentric is that right? is that possible. Or could I use my 3x telecentric before it which would make it F23.5 does this matter?
Many thanks for your help.
PST Mod and TEC140
- Has thanked: 20813 times
- Been thanked: 10486 times
Re: PST Mod and TEC140
Hi Alexandra.
You don't need telecentrics for PST mods, rather a barlow. The Magnimate from Astroboot should get you close to the f10 beam you need. Just mount it on one of these https://www.365astronomy.com/Filter-Ada ... hread.html then mount that in the 2" nosepeice of the etalon module.
My only thought is will you have enough infocus as i'm guessing you're not going to be cutting the TEC tube shorter
Alexandra,
Even with the ERF the PST mod would act as an aperture stop and bring the TEC to a100mm f10 system.
Thanks guys, so basically no then! oh well, will stick with the Solarscope at 100mm such a bummer that the Quark didn't last longer than 3 months, I got my best ever images with it
No, definitely not a no. You have a the 125mm free aperture DERF, so, as long as you make the beam entering the etalon f10 by doing what I suggested you will have a 125mm (f10) PST mod.
? but Merlin says not, he says the PST mod would stop it down to 100mm. So I am better off with the 100mm Solarscope?
I don't quite understand.
- GreatAttractor
- Has thanked: 747 times
- Been thanked: 757 times
As I understand, Merlin meant the configuration without any Barlows; in that case, the f/7 beam from your 140 mm, f = 980 mm 'scope would be only used by the PST as an f/10 beam (because of clipping), having f = 980 mm and D eff. = 98 mm.
ONLY if it is used in the native f7 beam of the TEC (or the f7.84 beam with a 125mm ERF), if you put a barlow before the PST etalon assembly and you get it to f10 that way then you will be using the full 125mm aperture.
- Has thanked: 3317 times
- Been thanked: 1907 times
You can put in new collimator and re-focus lenses to use the full aperture.
I have got a pair of 150mm and -150mm for my Meade 127mm F7.5 triplet. Yet to try it. Just x the FNo by 20 for your scope.
The lenses fit in a plastic Celestron/Skywatcher Moon filters.
I have removed the lenses out of the PST for my current Mod. Now its a 'Combo'.
One moved forward to reach focus on Maks and to not need to chop bits off refractors.
And the other sudpended after the PST in a Blue Lightning 48mm to 28.5mm adapter. That and the T2 to 28.5mm adapter are great for PST Mods for bodging together bits and holding empty cheap Chinese filters with 20mm aperture as baffles as ideal for the PST 20mm clear aperture. Sold by Agena Astro. They also do 1.25" extension tubes.
https://www.ebay.co.uk/itm/Astronomy-Te ... 2749.l2649
So I can just make a new nosepiece for the require position for the 127mm and swap the Moon filter over with the collimator lens in after.
Cheers. Andrew.
Cheers. Andrew.
Yup, that's another way of doing it, but would mean getting the 160mm DERF (with adaptor plate) to run full aperture (140mm). I did this with a 'f6' pst mod I ran a couple of years ago.AndiesHandyHandies wrote: ↑Fri Sep 04, 2020 9:17 am Hi
Cheers. Andrew.
