I am thinking in exchanging the helical focuser of a SolarMax 60 for one which can be easier motorized.
So my question is can the part 1 be separated from the part 2 ? What is inside part 1 ?
For what are those 2 cross headed screws there ?
Thnaks for your comments in advance :thanx:
SolarMax 60
- Has thanked: 9414 times
- Been thanked: 5578 times
- Has thanked: 7 times
- Been thanked: 9 times
Re: SolarMax 60
There's a very good thread on CloudyNights precisely about this but the site is down at the moment and I can't post the link...
Many members here have done the modification - look at Ken Crawford for example.
Will try to get back to you with the link...
Roberto
Roberto
Re: SolarMax 60
Hi Roberto,
Thanks. I made an exhaustive search in CN but did not find anything :silly:
Re: SolarMax 60
Yes indeed, you can make this change. I just did it to my SolarMax II 60 using a MoonLite focuser (and Stepper Motor) from MoonLite (www.focuser.com).
Basically the entire helical focuser unscrews, and you replace it with the MoonLite, then move the Coronado 90-degree over to the new focuser. I'm attaching a couple of pics of my mod'ed Coronado.
The one tricky nuance is that there is a lens inside helical that screws into the MoonLite, and the etalon then "loosely" screws down onto that. Ron Newman at MoonLite has the info (this is so new they don't have it on their website yet).
I can help also, if you are still looking at making this mod. Mine has been active for a couple of weeks and is working perfectly thus far!
Re: SolarMax 60
Hi John
I recently upgraded the helical focuser on my Solarmax 60 DS. Unlike the Solarmax II 60 with the Richview tuner, mine is (I guess), like the Maxscope 60 (circa 2007), in that it has an internal filter attached to the screw off base of the Solarmax. Ron Newman at Moonlite supplied the correct flange, (the only one it would fit is the Solarmax II 60 flange), to make the transfer of the internal filter to the new Moonlite focuser. However, Even though I am still waiting for good weather to really test the configuration, I would say that early indications are that the dreaded Coronado 'sweet band' has slightly diminsished when imaging (which is good), but when using the scope visually (not imaging), there is a noticeable 'ghost' towards the edge of the view, suggesting the optic path may be slightly off.
When placed back into the helical focuser its all working good again. So,I think transferring the internal filter to the new Moonlite is causing a visual problem. Maybe I was niave in thinking it would transfer without issue. Is there anything that you may suggest by way of people I could contact for advice etc? Sending the scope to Meade would cost a small fortune from the UK, and I don't really want to do that, and given I have modified it, they might not even take it back in for adjustment. Seems the internal filter has what appear to be very small allen bolts attached to the cell. Whether they can be used to minutely adjust the filter I am unsure, but there is a risk there too that I could make it worse if I chose to do this 'experimentally'.
I have tried to minutely adjust the Moonlite focuser via the four collimation screws, but this had little effect other than to make what is a heavy focuser potentially unstable and it could fall off the end of the tube! So I have reverted back to the focuser as delivered from Moonlite, which I am asured was collimated at the factory. I have attached an image of the internal filter to illustrate the allen bolts/screws.
Thanks in advance
Steven
Thanks in advance
Steven
