Lunt 50 mod. Cut the tube, or buy adapters?
- Oh, I get it now!
- Has thanked: 6 times
- Been thanked: 5 times
Hi all,
So I finally got my 102mm f/7 refractor. I was hoping it being f/7, I would reach focus by just attaching the Lunt module to the focuser M68 thread. Of course it didnt work. I need another 10-15mm
So the big question is; should I cut the tube (cheap! but I change the focal ratio slightly)? Or should I unscrew the whole focuser (don't really need it), add a M84 to M68 adapter and a 40mm extension tube (a lot of money for "nothing")?
What do you guys recommend?
- Has thanked: 404 times
- Been thanked: 372 times
Re: Lunt 50 mod. Cut the tube, or buy adapters?
If you can make it work without cutting the OTA, that would be preferred I assume.
- Has thanked: 3497 times
- Been thanked: 1447 times
Post a pic of the setup so can see it, there's always a way!
- Has thanked: 1381 times
- Been thanked: 1211 times
As Mark suggests, a picture (or diagram) of what you’re trying to achieve would be helpful.
Sounds interesting though.
- Oh, I get it now!
See this is the problem when you write stuff at 2AM
Pics time!
I just measured my Lunt 50. At F350, does the PT module, focuser and diagonal really make up 162mm (350-188) of that?
Pics time!
Don't cut the tubes - given you have the M84 fixings on the tube go for removing the focuser and using the m84 extension to get the correct spacing, by far the best way!
- Oh, I get it now!
Ofcourse. The front lens on the etalon assembly needs to be 162mm ahead of the focal point.
- Oh, I get it now!
lol of course! Brain is seriously not working today. But it's almost the weekend!
Thanks Mark
Thanks Mark
- Oh, I get it now!
Right, I got a bad case paralysis by analysis here...
I focused both telescopes just to see where the focus point was (with the same diagonal and eyepiece).
When put next to each other, they seem to focus at more or less the same spot. So, other than the M84-M68 adapter, do I even need an extension tube?
Or will I run into problems with the 20mm etalon by moving it in?
Try it under the sun, what's the worst that can be? you have to buy an m68 extension!
- Oh, I get it now!
- Oh, I get it now!
Right, I need to double check something here, as another solar modder is confusing me!
The 2" Baader 35nm H-a filter goes BEFORE the PT module right? My buddy here says to use it in the diagonal instead, since the Lunt PT module already has a filter in it. Now that is true, but I thought the Baader filter was there to take some of the heat away from the Lunt filter?
The Baader 35nm Ha is acting as an energy rejection filter (ERF), so it should go in front of the etalon assembly. I see from the image that you have a few degrees of tilt on this, which is correct as it will help reduce unwanted reflections.
Looks good.
As Mark suggests, give it a try and see what you get. If it doesn’t quite work out you can always have a custom spacer made to achieve the exact positioning.
Looks good.
- Oh, I get it now!
That is what I thought! I guess there is more than one way to do it. Obviously having a filter in the diagonal works for him!
Cheers Stu!
Cheers Stu!
