Coronado BF10 straight-through conversion?
- Has thanked: 60 times
- Been thanked: 78 times
Since I only image, having a straight-through version of my BF10 would be nice. Has anyone in here done this? On paper, it seems pretty straightforward. But I bet it's not, or more people would have done it!
Clear sunny skies!
Chris
Lunt LS50THa
Lunt "Luntair" Altair 102ED
Chris
Lunt LS50THa
- Has thanked: 20783 times
- Been thanked: 10470 times
Re: Coronado BF10 straight-through conversion?
No reason why not!
- Has thanked: 1188 times
- Been thanked: 1382 times
Yeap, its fine to do. There's nothing special going on with the diagonal. It's a basic star diagonal. The eyepiece side has the blocking filter. It's usually glued on (the 1.25" nose is glued, you'd have to break that adhesive to unthread it).
I converted one to straight through and even added a helical focuser to it, just to have more options to play with distances.
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Just wondering if this can be done with the Lunt wedge too.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
No, with the Lunt wedge the filters are mounted in the diagonal body rather then the nosepiece sections.Stardust5858 wrote: ↑Sat Feb 13, 2021 2:48 pm Just wondering if this can be done with the Lunt wedge too.
- Stardust5858
Thanks Mark, good to know.marktownley wrote: ↑Sat Feb 13, 2021 3:07 pmNo, with the Lunt wedge the filters are mounted in the diagonal body rather then the nosepiece sections.Stardust5858 wrote: ↑Sat Feb 13, 2021 2:48 pm Just wondering if this can be done with the Lunt wedge too.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
OK! How long does the adapter have to be?
Thanks guys!
Thanks guys!
Clear sunny skies!
Chris
Lunt LS50THa
Chris
Lunt LS50THa
Shouldn't matter, there's no optics that re-focus the light cone, just passes it through. Ideally make it as short as possible, but without masking the light cone. It's always easier to get distance out of the focuser, than back focus into the focuser.
Here's a straight through conversation and I even added a helical focuser:
Here's the BF retro fitted into an eyepiece barrel basically (or the 1.25" nose of any diagonal):
Excellent!
Clear sunny skies!
Chris
Lunt LS50THa
Chris
Lunt LS50THa
