Sweet spot, banding and tilted etalons ...where are the limits ?
Has thanked: 10 times
Been thanked: 800 times
Re: Sweet spot, banding and tilted etalons ...where are the limits ?
Post by MapleRidge »
Hi Christian...
Thanks for the completed math on the calculations.
I had always though the 'sweet spot' on my mod was less than optimum since the etalon/collimators are designed for a f7 scope, but I have it on a f8 OTA.
My original mod with this etalon was on a 100mm, f10 scope and I think the sweet spot increased as the focal ration move closer to what it was designed for. When I run the math on the 100mm scope it shows the radius is smaller, close to 0.16 deg by my math.
C9.25 Edge + Stellarvue 110, f7 or C14
Deep Sky Work - Canon 60D (Ha mod), SBIG STF8300/FW8, ONAG
Planetary Work - SBIG CFW10, ASI290MM/ASI462+ADC
8' Diameter Dome
MI250 Mount carrying:
Celestron CR-150 150mm, f8 OTA Modular Setup
Ha configuration: 2xDSII/B1800Ha/Daystar ERF as modded Ha Scope
WL & CaK configuration: Lunt WL Wedge or Modded B1800CaK Wedge
Lunt LS80PT/LS75FHa/B1200Ha
Daystar Quantum 0.45A SE, Quark Combo Chromosphere,
ASI1600MM, ASI174MM, ASI290MM, PGR Grasshopper Express
LeoD
Has thanked: 168 times
Been thanked: 201 times
Post by LeoD »
Very informative thread!
christian viladrich wrote: Mon Mar 01, 2021 1:15 pm BTW, there is also a possible combinaison with a double stack Lunt 80 mm internal etalon. I don't remember what is the actual diameter of this etalon.
The Lunt LS80MT has 51mm tilted internal red ERF in front of 45mm clear aperture etalon and DSII-SFPT module of 36mm c.a., joint next to it.
The same as Marty, I'm curious to pair the Lunt, in my case DS rear system, with a bigger frac f/7. Seems promising, though.
With my given 130/7 according to Christian's formula, I have 0.34° diameter of the 'sweet spot' i.e. 2/3 of the disk.
How to calculate a lens in front of the etalon? with detached native collimation lens or as it is?
Leo
Been thanked: 306 times
Post by christian viladrich »
I think George9 on Cloudy Night Forum has a double stack configuration with his 155 mm Astrophysics. I am pretty sure he has at least one Lunt 80 mm etalon, but I don't remenber whether the other etalon is another Lunt 80 mm or a Quark.
I don't remember if George9 is also on SolarChat ?
Here is an example of double stack Lunt 80 mm on a 204 mm refractor :
http://www.astrosurf.com/topic/144876-s ... m-h-alpha/
