Hi Christian...
Thanks for the completed math on the calculations.
I had always though the 'sweet spot' on my mod was less than optimum since the etalon/collimators are designed for a f7 scope, but I have it on a f8 OTA.
My original mod with this etalon was on a 100mm, f10 scope and I think the sweet spot increased as the focal ration move closer to what it was designed for. When I run the math on the 100mm scope it shows the radius is smaller, close to 0.16 deg by my math.
Sweet spot, banding and tilted etalons ...where are the limits ?
- Has thanked: 10 times
- Been thanked: 800 times
Re: Sweet spot, banding and tilted etalons ...where are the limits ?
Deep Sky Work - Canon 60D (Ha mod), SBIG STF8300/FW8, ONAG
8' Diameter Dome
MI250 Mount carrying:
Celestron CR-150 150mm, f8 OTA Modular Setup
Lunt LS80PT/LS75FHa/B1200Ha
8' Diameter Dome
- Has thanked: 168 times
- Been thanked: 201 times
Very informative thread!
The same as Marty, I'm curious to pair the Lunt, in my case DS rear system, with a bigger frac f/7. Seems promising, though.
With my given 130/7 according to Christian's formula, I have 0.34° diameter of the 'sweet spot' i.e. 2/3 of the disk.
How to calculate a lens in front of the etalon? with detached native collimation lens or as it is?
Leo
The Lunt LS80MT has 51mm tilted internal red ERF in front of 45mm clear aperture etalon and DSII-SFPT module of 36mm c.a., joint next to it.christian viladrich wrote: ↑Mon Mar 01, 2021 1:15 pm BTW, there is also a possible combinaison with a double stack Lunt 80 mm internal etalon. I don't remember what is the actual diameter of this etalon.
Leo
- Been thanked: 305 times
I think George9 on Cloudy Night Forum has a double stack configuration with his 155 mm Astrophysics. I am pretty sure he has at least one Lunt 80 mm etalon, but I don't remenber whether the other etalon is another Lunt 80 mm or a Quark.
I don't remember if George9 is also on SolarChat ?
Here is an example of double stack Lunt 80 mm on a 204 mm refractor :
http://www.astrosurf.com/topic/144876-s ... m-h-alpha/
