Solar H alpha with eBay filters
- sullij1
Re: Solar H alpha with eBay filters
BTW, you need to post that panorama using the Stephen method. That Pic rocks! :rockon:
BTW, Stephen, If you are lurking, thanks you soooooo much for moving the thread. The main thread gets so busy Peters effort could be lost in a matter of a day or two and that really would be a shame.
Thanks Man
Thanks Man
Look Up!
- sullij1
Dude those pics SWEEEEEEEET! Don't sweat too much on details. They will come in time and the excellent mentors found here. As Merlin says "onward and upward from here!"
Look Up!
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Thanks again Joe!
Here's a re-work of the panorama - I like it better.
The CaK shot was done a little differently. Omega filter pair placed between a (negative 150mm) collimating lens and a positive (120mm) refocuser, both Edmund achromats. It was done with 80mm f6 refractor. Full solar disk on the 2/3" ccd.
- Has thanked: 20939 times
- Been thanked: 10587 times
Thats working pretty well Peter. When you get into it more try some flat fielding, that will even things out considerably...
Hi Peter
very good job with this filters. I like your setup.
The results you showed so far match exactly my findings. I'm sure we can do better.
Peter,
Very glad to see your results using the Ebay Omega filters. As pointed out, there are a number of ways to approach and solve this problem. I'm happy to see that my first attempt is leading to others using this approach. Keep up the great work.
All the Best,
- Dave Groski
All the Best,
- Dave Groski
- sullij1
Peter,
Gotta run to a meeting but I want to point you to the flattening tutorials in the tutorial section of the forum. These out of focus disk flats have yet to work well for me but they may help with your images. I'm having better luck with making a Fitswork solar flat. I will explain later.
Look Up!
Thanks, Joe.
I've attached drawings for the telecentric system used for these pix. The barlow magnification factor was about 2.2. Three Edmund Optics achromats were arranged as shown. The Gerd Neumann filter holder was used to attach the filters using kinematic lens mounts (eBay). Photos in next post.
This was very helpful!
- sullij1
Peter,
Hi peter,
The solar flat tutorial in the tutorial section worked fine for large scale images like you have presented. I could not get them to work for full disk images. I had better luck using Create a Solar Flat function in Fits works. I then saved the flat, took it to Photoshop and added it as a new layer over the original image. I then used multiply and other lighting effects and sharpen at 50% transparency until I had an effect I liked. I then adjusted transparency to where the image looked best. Soo far that has worked best on my full disk white light and calk stuff. Hopeful others with Ha talent will add more.
Joe
Link if you don't have it:
www.fitswork.de/software/softw_en.php
Hi peter,
Joe
Look Up!
- p_zetner
Here's a full disk image taken yesterday. The dated image is a photomerge of about six images with some flat fielding. The undated image (sharpened and curves) shows the high contrast "sweet spot" doesn't cover the entire field of view. I moved the scope around to get different regions of the solar disk inside the sweet spot - hence the photomerge.
- sullij1
Keep it up, every image gets better. Yer kicking ass bro! :rockon: :
I am certian there will be a learning curve that goes with these filters for best image result. Right now Peter, U-R the GURU!
Joe
Joe
Look Up!
- sullij1
Mark T,
If you pass by here, could you do us a favor and do a cut and paste of the pic/post of your monocular device and give us a lil discription of how to build it and what to expect from it?
It would be cool to have different versions and approaches to using these filters that might fit various pocketbooks.
Cheers,
Joe
Cheers,
Joe
Look Up!
- sullij1
Dave G or Colin K,
Would you favor us with a repost of the link to the Groski files such that we have all options available on one thread?
Best,
Joe
Best,
Joe
Look Up!
- sullij1
BTW, Mark,Dave and Colin,
There is a PLEASE that goes with that. There is an old Jarhead in me that forgets the word. My apologies.
Joe
Joe
Look Up!
Hi Peter
great results
great results
Mark T,
Cheers,
Joe
I don't have any pictures; all I did was pretty straight forward. Took a 6x30 finder scope, blue tacked the Omega etalon on the objective, put the blocker from my BF10 in the base of the ep, put baader 7nm Ha filter also over objective and looked at the sun. Wiggled the etalon till I could see blotchiness on solar disk and could just make out some proms. The view was, as you might expect, looking at 6x magnification. Not really a long term usable thing, more of a play around one afternoon...
Cheers,
Joe
Joe
This is all I have:
http://www.considine.net/dgroski/
Joe
This is all I have:
- sullij1
Mark,
Thanks, that might be just enough to get sombody started on a monocular. I remember someone had made a mono out of a binocular using the Cromix sun device. Such a thing-using what you have given us in your brief could be an option for visual users. I will try and find the old pic of the cromix-sun mono.
I had thought about adapting a rifle scope for visual as many of them contain a telecentric lens group. Just a thought.
Thanks again,
Joe
Thanks again,
Joe
Look Up!
- sullij1
[quote]BTW, Mark,Dave and Colin,
Joe
This is all I have:
That's all we need! Thanks Colin :
Joe
This is all I have:
Look Up!
More results using the Omega filter pair:
http://www.pbase.com/p_zetner/solarphotos
You're getting the best results i've seen so far with the Omega filters - congratz! 8)
- p_zetner
I'm slowly expanding the equipment section of my photogallery. Feel free to browse.
http://www.pbase.com/p_zetner/opticsdesign1
- sullij1
WOW, Peter thanks for the detailed instruction! You truly represent the sprit of community sharing!
Thank You!
Joe
Thank You!
Joe
Look Up!
Just joined the SolarChat forum. My first post!
I too just ordered the H-alpha pair from OmegaBob, and started doing a little searching on Dave Groski's SolarScope, which led me here. WOW -- this place is EXACTLY what I was looking for.
Imagine I'll be doing a lot more listening than posting here, at least for a while.
Looking forward to learning all about this new (for me) aspect of the astronomy hobby.
-- Shindog
-- Shindog
Hi Mark (shindog)
welcome to that wonderful TOS free site. Have sun, have fun
Thx. I figure any site that has "Silly Rules" is my cup-o-tea.
--Shindog
--Shindog
With regards to the donor scope for an eBay / OmegaBob H alpha project...
Dave Groski's article specs a 60mm f/16.7 objective. Having a 80mm 800mm on hand, would this be an acceptable testbed (while continuing to scrounge for the specified optic)- if one first masked /stopped down to 48mm? Obvious loss of light-gathering ability, etc...
Thanks
--Shindog
Thanks
--Shindog
- sullij1
Hi Wah!,
No the blocking filter is the 2nd one of the pair. You will need an ERF on the objective.
Look Up!
- sullij1
WHA! I think Peter used two .15 Ha with excellent results. Probably about the same price. Check the thread but I think that is correct.
Look Up!
I can find the filters have been relisted now!
Hello!
Can you, please, give the direct link for these filters?
Peter, may I have a few questions about your solar telescope?
1. What is the diameter of your 0.15nm filters?
2. What is the transmittance peak?
3. What is the central wave length of transmittance?
4. How much do they cost?
5. Does the peak of transmittance shifts with temperature during observing session?
6. Do you need to adjust the tilt of these filters from one observing session to another?
Thanks,
Valery.
Hello!
Thanks,
Valery.
Hi Valery
[quote]I can find the filters have been relisted now!
Hello!
Thanks,
Valery.
Hi valery,
welcome!
Answers based on my experience of these filters:
1) 25.4mm
2) varies from filter to filter
3) varies from filter to filter
4) not sure, would have to look on ebay, they seem to vary between batches
5) yes
6) yes
IMHO a PST mod is much more effective and a better way forward...
mark
Hello!
Thanks,
Valery.
Hi valery,
welcome!
1) 25.4mm
5) yes
6) yes
mark
- sullij1
- sullij1
The filters Peter used are not currently available as mark pointed out. I will see if I can find the old link so you would know what to look for.
Mark is right but these are fun to play with..
Look Up!
- sullij1
BTW, Valery is a well recognized and experienced telescope builder/vendor from the Ukraine and will be an asset here. He has already developed a large aperture Ha system that has a an awesome fully illuminated filter. We hope to see some interesting developments from you Valery and thank you for taking the time to contribute and visit with us.
(I may have suggested he visit with us. :whitsle: )
Look Up!
- sullij1
This is from my Ebay history I think they are 25mm diameter. I am certian he will repost them soon or you can email Bob Johnson and ask if he has more. He often does. Valery You have his ebay store address. His email address is at the bottom of the left hand side menu.
Optical Interference Filter 656.3 H Alpha 0.15nm Band-Pass for Double Pass
Photos not available for this variation
Item condition:New
Ended:Nov 10, 2012 07:19:18 PST
Price:US $130.00 [ History:10 sold]
No additional import charges at delivery!
This item will be shipped through the Global Shipping Program and includes international tracking. Learn more
Shipping:$5.00 Standard Shipping | See details
Item location:Brattleboro, Vt., United States
The filter set I linked you to is Bob's Ha pair. One of them is the .15nm filter and the other is a dichroic interference wedge tuned to Ha. Basically the etalon.
Item condition:New
Look Up!
Hi sullij1,
(Sorry, I don't know your real name).
I think you overestimated my achievements in solar telescopes building. I just tried to make a 150mm F/5 solar H-a telescope affordable for those, who can't afford a 152mm Lunt telescope. It seems that the scope I made does work as were planned. Full disk in excellent 0.7A H-a, excellent sharpness and resolution. Visual contrast is OK, but it fully depends of filters I used. Photographically (b/w CCD) the contrast is very good and allows to take very detailed pictures quite easily.
This scope can be upgraded to 0.5A within one or two minutes by adding one more 0.7A etalon and some more adjustment.
Now I need to finish the development of the mechanical parts - to make this scope truly universal solar machine. This will take a month or two. So, for new warm season I will be ready to offer to solar observers community my upgrade kit.
Here you can see some my photos taken recently with this 150mm F/5 0.7A solar telescope. I am not any kind of master in photography and my learning curve is quite short - it begins in the middle of October. So, don't criticize my works too much.
http://www.astronomy.ru/forum/index.php ... lbum;in=52
Valery Deryuzhin.
ARIES Co., Ukraine
Hi sullij1,
Valery Deryuzhin.
ARIES Co., Ukraine
- sullij1
Valery, my name is Joe and your work is excellent and appreciated.
Your optical prowess with Aries has been observed and respected on such product as the Astro-Physics 10 Inch (25.4cm) f14.6 Maksutov, the Chromacor and the SAFIX corrector for spherical aberration. To mention just a few.
I don't underestimate you sir. "Please" continue to help the less well heeled among us garner better solar equipment. Thank you for accepting my invitation.
Look Up!
- sullij1
Valery,
Based on some of the questions you had on CN you may find these threads interesting:
http://solarchat.natca.net/index.php/en ... ternatives
And CaK
http://solarchat.natca.net/index.php/en ... 0&start=60
http://solarchat.natca.net/index.php/en ... 600-module
http://solarchat.natca.net/index.php/en ... -4nm-cal-k
http://solarchat.natca.net/index.php/en ... ctually-do
http://solarchat.natca.net/index.php/en ... er-arrives
http://solarchat.natca.net/index.php/en ... ine-filter
http://www.ebay.com/itm/Optical-Filter- ... 4849f82ecf
Omega also sells a CaK / 80A pair by request, if you’re interested. Again I think these are around 4nm FWHM. Merlin 66 and Mark Townley can give you information on those. I just acquired them and have not a lot of time to play with them yet.
Also you may want to post you Ha scope information in the Commercial Solar filters/Hardware section.
I will also find an up load site for your raw avi data (if that is what it is) and post it later. (can sombody help me here?) I would like a crack at processing some of the raw data from your new Ha scope. The comb (if that is what you call it) looks similar to the Omega comb when Omega’s are done right. (your filters are better)
Hope that helps get you going on some of the stuff we discuss on a term of service free (TOS Free) site.
Joe
And CaK
Joe
Look Up!
