TAL 100RS PST Stage 2 Mod
uplooker
Post by uplooker »
Hi All,
Well I thought that it was only fair, after all the daft questions i have posted on here, to post some pictures of the slow progress i have made on my TAL 100RS PST Stage 2 Mod.
I have cut a slot in the tube to accept an internally mounted 75mm Baader D-ERF. A friend who has acccess to some forming rollers rolled the patch to match the profile of the TAL tube.
I glued (extremely strong industrial glue) some anchor nuts to the inside of the TAL tube, at the ends of the slot, so that I can attach the patch.
I have attached a fixed lens mount to the patch, this will hold the D-ERF within the light path.
The only thing I need to do is cut the tube to get the etalon to the magic -200.
I am just waiting on a couple of elements to turn up and I should be good for 1st light. If everything goes to plan I hope 1st light will be this weekend - fingers crossed
Ian
Been thanked: 1 time
Re: TAL 100RS PST Stage 2 Mod
Post by swisswalter »
Hi Ian
looks cool, good luck on first light
Has thanked: 20757 times
Been thanked: 10442 times
Looks good to me Ian!
MjrTom
Post by MjrTom »
Looking great Ian, good to see its progressing nicely :)
Has thanked: 174 times
Been thanked: 619 times
Post by Merlin66 »
Well done!
So far so good.....
