DIY heat sink for Herschel wedge builders
- Has thanked: 173 times
- Been thanked: 615 times
I've just received a Ceramic tile with small holes, 2-5/8" sq. x 1/2" thk., #M3156 from Surplus Shed.
I think this could make a great rear heat sink for a DIY Herschel wedge.
Re: DIY heat sink for Herschel wedge builders
Hi Ken,
I hope you do not think me being condescending by asking, but have you built a DIY Herschel Weddge before. I would be very interested in how to go about it.
I hope you do not say "Yes, i have a comprehensive PDF file on how to do it". The last time you said something like that to me I ended up putting together a TAL 100RS PST Stage 2 and lightened my pocket by a considerable sum
Ian
Ian
Hold on to your wallet Ian, the answer is coming for sure.
Allan
http://solarchat.natca.net/index.php/en ... ge-take-ii
If you can find a suitable prism wedge and use an existing 2" diagonal it's not that expensive - much much cheaper than the Baader or Lunt offerings.
Doh, I knew i should not have posted that reply to Ken's original - and to top it all I clicked on the link Ken posted in his reply
Don't worry, i am not about to dash out and persue this avenue - just yet
Ken,
I do not doubt your knowledge and ingenuity, but my pocket has a distinct dislike for your posts :unsure:
Ian
Ken,
Ian
There is a ATM on the Cloudy Nights ATM forum that has published grinding your own 15 deg prism instructions. I don't have a link but their search engine should find it.
- DSobserver
- Been thanked: 19 times
No,
I just used it visually on a TS102 refractor...
It performed very well.
- Bob Yoesle
- Has thanked: 540 times
- Been thanked: 807 times
You don't really need to use a wedge prism for a solar filter application. In fact, you can just reverse the right angle prism form any standard diagonal and do the same thing as a wedge prism:
I would blacken the side opposite from the eyepiece with a good flat black paint job...
You still need to use the ND 3 and ancillary filters AFTER THE REFLECTION to achieve a safe level of filtering. And you could incorporate any of the similar methods of venting &/or cooling to enclose the prism housing... such as a CPU heat sink, TEC, etc.
Bob B)
Bob B)
Hi Bob
thank you for the information.
Bob B)
That is good rough math but if an error of 10% in throughput matters then make sure to study Brewster's Angle. I like the idea.
Bob B)
Hi Colin
that is an interesting response. How would I construct a wedge having say 10 or 20% reflection? I'm always missing light when I'm doing close ups in WL and CaK
Walter,
can't be done with a bare prism...the maximum reflection is around 4%.
To get any higher the front surface would have to be partially reflective coated, or use a 10/90 or 20/ 80 beamsplitter plate....
Walter this will be an easy read for you:
http://en.wikipedia.org/wiki/Brewster's_angle
You can adjust the reflectivity and it is quite polarization dependent but Ken is right you will not increase it.
Hi Ken, Hi Colin
thank you very much. Now I have things to go after. I guess I have to start with a 10% beamsplitter
- Has thanked: 20424 times
- Been thanked: 10243 times
A 45 degree hot mirror is what you need walter - i'm having the same closeup problems in WL @ CaK too. There's a few options on Edmunds Optics site i've been considering. I'll fish out some links for you later on, got to go and get ready for work now...
Mark,
I think you mean a Cold mirror...
http://www.edmundoptics.com/optics/opti ... rrors/1900
Problem is that they reflect 80% of visual - too much for a wedge application....
Plenty of beamsplitter plates to choose from.
http://www.edmundoptics.com/optics/beam ... tters/2035
(I use them for guiding on the spectrosocope - a "special" 4r/92t)
The obvious solution is to use a lighter ND filter after the wedge ...
Hi Mark, Ken and Brian
thank you very much for your help
@Brian I'm not using any ND filter at all after the wedge
@Mark I'll be lookng forward to your findings
@Ken I'll have to look into the beamsplitter plates, thank's for the link
Mark,
Nope, I most definitely mean a hot mirror http://www.edmundoptics.com/optics/opti ... rrors/1492
As you note cold mirrors reflect 80% of the visual, that's no good - that is what we're trying to keep.
I'm not going to use this with a wedge, I intend using instead of a wedge
Walter and I are already using shortpass/longpass filter combinations with our CaK rigs. The aim is to be able to image at several metres focal length in CaK, yet still keep the exposure shorter than 1/1000second. Imaging at 1/77s or 1/250s in CaK wavelengths at these silly focal lengths just introduces blurring as a result of the seeing. If you can image at ~1/5000th sec exposure things are much improved. You should know by now Ken we're not trying to do anything sensible
- Bob Yoesle
Hi Mark,
As another source for hot mirrors (and other optics), you might be interested in Thor Labs:
http://www.thorlabs.com/navigation.cfm?guide_id=2234
In addition to Colin's link, another good tutorial on reflection / refraciton can be found here:
http://en.wikipedia.org/wiki/Fresnel_equations ;
and here:
http://www.telescope-optics.net/reflection.htm
Bob B)
and here:
Bob B)
