I use the SW accufocus motors on almost all of my gear - cheap and does the job well. I have these focuser motors on my ED80 for Ha solar imaging and the C11 for spectroscopy...
Just before I left Belgium I managed to aquire a Baader Herschel Wedge and a TS 102 f11 Achromat.
The TS102 has been converted to a modded PST as well.
This scope has the generic 10:1 Crayford and I needed a fine focus control for solar imaging.
The attached images show the set-up:
Based on the Std SW/Orion focuser motor...
I already had a 28 tooth wheel and 80 tooth belt from another project (!!)
I measured the "gap" below the Crayford body as 9mm and found a piece of MDF and a 1.6mm aluminium plate which stacked up.
By removing the two small M3 screws from the base of the Crayford and drilling a 6mm diameter hole (to clear the locking screw) I managed to come up with a pretty compact solution.
Pretty self evident, but works very, very well for fine focusing with the DMK camera.
Any questions let me know.
I should have said the belt just drops off for rough focusing with the main knobs....
SW motor fitment to stock 10:1 Crayford focuser - great improvement!
- Has thanked: 174 times
- Been thanked: 619 times
- Been thanked: 4426 times
Re: SW motor fitment to stock 10:1 Crayford focuser - great improvement!
Hi Ken...
Great adapatation of the motor for focusing.
I used a simalar motor and controller to motorize the tilt tuning on my LS50 and LS75 etalons...made a long reach much less necessary
Brian,
I just use the "Patented Vegemite tilt controller" for the DS etalons on the ED80 ;-)
Hi Ken
that is a great, compact and clean mod
Thanks!
"No ants were killed in the making of this mod"
Hi Ken
that is a major improvement during developping of solar stuff :whistle:
- Has thanked: 20803 times
- Been thanked: 10478 times
Nice mod there Ken!
I like it Ken
But I don't have a Crawford yet
Is any Crawford OK ?
What / who is the motor from ?
How is it controlled ?
Col
Col
It will work with any Crayford focuser....
The motor and handcontroller is the standard Skywatcher/ Orion AccuFocus DC focus motor.
Thanks very much Ken
That looks like what I need, I struggle with focus.
I am saving for a Crawford & will add this to my wish list.
Col
Col
