Reflection ghosting from Blocking filter?
- Has thanked: 174 times
- Been thanked: 619 times
I use a Coronado BF15 blocking filter on my PST88 mod.
I noticed yesterday a definate ghosting of the FOV in a 21mm eyepiece.
Rotating the ERF, etalon tuning, blocking diagonal or eyepiece made no difference to the extent, intensity or position of the ghosting.
However, I noticed if I slightly loosened the blocking filter, the ghosting would move....
I'm therefore concluding that its caused by the reflection from the front "mini-ERF" element in the blocking diagonal bouncing back to the rear re-focusing lens on the etalon assembly and then reflected back again.
I'm looking at adding a series of baffles between the etalon and the diagonal. If this doesn't work the next stage would be to remove the "mini-ERF" - it's already redundant with the Baader D-ERF up front.
Any comments???
Any comments???
Re: Reflection ghosting from Blocking filter?
Hi Ken
yes, indeed, remove the little ERF, any glass not beeing necessary asks for trouble
- Has thanked: 20825 times
- Been thanked: 10498 times
Yes, remove the mini ERf, no need for it...
Thanks everyone.
I tried a series of three baffles - made no real difference.
removed the "min-ERF" from the BF15 and the main reflections disappeared!
Just had the five minutes of clear sky (at -8 degrees)in Brussels....ready for the next time.
I have a various collection of T thread spacers between the etalon and the BF...I measured the position of each joint and cut a diaphragm diameter to suit the spacing - I had a total of four baffles....
Interesting comment..I have a BF10 from a SM60 scope - I should try that for comparison....
Stephen has said before the BF15 isn't the best (I think...)
Can anyone expand on that comment??
When used with which system?
I checked both the BF10 and BF15 with the spectroscope..the bandwidth is almost identical but the BF10 had a slightly better transmission efficiency...that was about it.
What sort of difference are we talking about % wise for the transmissions Ken?
I'd need to pull the data to be 100% sure, but of the order of 10-15% ie a 30% transmission going to 35-36% - something like that.
Neo,
it's not the blocking filter at the eyepiece end that's the issue...it's the "mini-ERF" inside the nosepiece (This is the same size for both the BF10 and BF15)-about 15mm diameter.
Which "tilt" do you see? In the BF diagonals, both the "Mini-ERF" and the rear blocking filter appear to be square to the body and the optical axis. Any chance of a photo?
Yes, like the tilt on the front D-ERF, a tilt on the BF assembly would make a difference.
Neo,
It's OK....I pulled the eyepiece holder off the blocking filter diagonal and yes, you can see the tilt of the final blocking filter from the inside clearly.
Thanks for the info, appreciated.
Ken, do you have the bandpass/width / transmission data for this mini erf that you unscrewed?
I add all this ERF glass and BF glass on my Lyra Optic Ha scope and almost before using it I need to remove some of it, like a mini ERF . Now where did I leave my hammer?
Well that was easy, I had a steel engineering right angle which was a perfect fit on the locking collar. A quick tweak to remove the big blob of silicon that Coronado had used to lock the collar in place and the filter is out.
