Collimating solar scopes
Am I correct in thinking that light only travels through an etalon in one direction so using a laser collimator will not work?
Allan
Re: Collimating solar scopes
The transmission of a hydrogen alpha solar filter set is going to be so small that unless you're using a laser tuned to hydrogen alpha wavelength you're unlikely to get a usable response in either direction.
However there's no reason why you can't collimate the scope without the filters in: and adding the filters shouldn't upset the collimation in any way.
Thats good Brian, it should work with the pst mods,. However, I was thinking about how I might collimate my LS60T mod. I cannot remove the etalon from that one.
Allan
- Has thanked: 20442 times
- Been thanked: 10247 times
I've used a cheshire eyepiece in all of my solar scope mods... Definitely worth doing.
Good news, I bought a Baader MkIII laser. I removed the BF from the LS60T and I could shine the laser all the way through the lunt etalon and see the laser dot on a piece of paper fixed to the end of the C6. I then covered both ends of the C6 tube with a paper target. I made a tiny hole in the centre of the near target and a cross in the centre of the far end target. Then it was simply a case of aligning the lunt so that the beam went through the hole and aligned with the cross at the other end.
Allan
Good stuff Alan. I will have to put a laser collimator on my Christmas list...
For my Lunt/C6 project it turned out to be invaluable. I don't think I could have lined up 2 separate scopes without it.
Allan
There are diodes that are close to h-alpha and others that are a few nm off. If you are only collimating the objective then it does not matter but for the entire assembly you want a 658nm diode and temperature tune it. I am lucky enough to have spent 10 years developing a tunable laser in this frequency range for another project. But, sometimes luck favors the well prepared.
This is really not worth while for collimation but perhaps some people will find it interesting. This is one of my lasers.
http://redlum.xohp.pagesperso-orange.fr ... laser.html
