Williams 102 mod?
Robin
Williams 102 mod?
Post by Robin » Sat Jun 08, 2013 9:11 pm
In my quest to upgrade from my PST I have enquired as to buying a new Meade or Lunt and it has been suggested that I could mod a refractor -question, I have a Williams Megrez 102mm which I use for DSO imaging, would this be suitable for modification. I would not want it to be permanent but be able to remove filters and use for night imaging. I assume from studying the posts on the forum that I would need a BF and a ERF for this conversion. Can anyone tell me if this is a goer and what filters I would need to purchase and where to get them
Many Thanks, great Forum
Robin
Lunt LS60THa / B1200 / LS60Fha / DMK51AOU2 / DMK21AOU2 / Revelation 6 & 8" RC / Opticon Minitower 11 & Startracker / Mad Red Setter and understanding Wife
Re: Williams 102 mod?
Post by swisswalter » Sun Jun 09, 2013 7:07 am
Hi Robin
depending on the focal length there is more to do. Has it f/10 ?
Robin
Post by Robin » Sun Jun 09, 2013 8:54 am
Hi Walter
Its a f/7
Robin
Post by swisswalter » Sun Jun 09, 2013 12:57 pm
Hi Robin
so you need a 25mm negativ lens with -145 mm FL to be put up front the PST mod
Has thanked: 1287 times
Been thanked: 534 times
Post by marktownley » Sun Jun 09, 2013 7:15 pm
OK, easiest and cheapest way to mod with this scope:
Get a 75mm Baader D-ERF http://www.teleskop-express.de/shop/pro ... ation.html 255 Euros
Get a PST nosepice ~£25
You would then have a 70mm stage 1 PST mod for less than 300 quid.
To improve, go to stage 2, with a couple more adapters and a SCT focuser....
Robin
Post by Robin » Sun Jun 09, 2013 8:09 pm
Hi Mark
Thanks, where could I obtain a PST nosepiece £25 Or I don't mind investing in a BF and would I need a filter holder to match the 102mm ?
Robin
Post by marktownley » Sun Jun 09, 2013 8:38 pm
http://www.aokswiss.ch/d/zub/adapter/50.8-pst.html
Used like this in the picture you would not need another BF. I can machine you a filter cell holder for the D-ERF.
Post by swisswalter » Sun Jun 09, 2013 9:23 pm
Hi Mark
can you also maschine a filterholder for a 203 mm lens with threads :?
Post by marktownley » Sun Jun 09, 2013 9:49 pm
Hi Mark
I could if you need me to - I assume to hold an ERF? It wouldn't have threads, but would be easy enough to engineer an interference fit...
Post by swisswalter » Sun Jun 09, 2013 10:18 pm
Hi Mark
great, absolutely great
We will discuss that at the next outreach at wolfhalden ;-)
Post by marktownley » Sun Jun 09, 2013 11:23 pm
If you give me the sizes beforehand I will bring it to Wolfhalden for the outreach ;)
Has thanked: 4 times
Been thanked: 20 times
Post by Merlin66 » Mon Jun 10, 2013 12:20 am
Robin, a couple of comments...
1. Make sure you have enough space to get the PST etalon 200mm inside prime focus.
2. The PST etalon works at f10 (unless you change lenses on the assembly) which will result in an effective 70mm aperture.
Robin
Post by Robin » Mon Jun 10, 2013 9:15 am
Thanks Guys for all your advice I am now going to consider whether to carry out a mod or invest in a new telescope all together, I want to get the best out of imaging within my budget a mod may not be the answer. Thanks again
Robin
Post by swisswalter » Mon Jun 10, 2013 5:29 pm
I am now going to consider whether to carry out a mod or invest in a new telescope all together, a mod may not be the answer. Thanks again
Robin
Hi Robin
maybe I do not understand english very well, but you could consider next time, when you set up a help mod question, to narrow down the search field a little bit
Robin
Post by Robin » Mon Jun 10, 2013 5:37 pm
OK. query now resolved thanks. Your English is very good :)
Robin
