PST Mod
Re: PST Mod
Hi Chris
you can use any focuser, but using the sct focuser let you attache the end of the PST directly to it
- Has thanked: 174 times
- Been thanked: 619 times
Re: PST Mod
Depending on your set-up, you can use any focuser. The 2" fitting is normally used in conjunction with a 2" nosepiece adaptor on the PST etalon. Infact, you can use a "spacer" rather than a focuser to hold the etalon....once it is positioned correctly (at the majic 200mm inside prime focus) it NEVER moves.
What is required is a focuser after the etalon, between it and the camera/ eyepiece. This final focus will be 200mm behind the etalon. I, and others, use a Borg helical focuser in this position.
Hope this helps.
Hope this helps.
- solarchat
- Site Admin
- Has thanked: 84 times
- Been thanked: 1384 times
Re: PST Mod
I moved this to the scope mods section..
Stephen W. Ramsden
Atlanta, GA USA
http://www.solarastronomy.org
Atlanta, GA USA
