The CaK 80A filter arrives!
Has thanked: 174 times
Been thanked: 618 times
Post by Merlin66 »
The ebay CaK filter arrived this morning...a few wraps of gaffa tape and it now sits nicely in a 1.25" filter cell.....
As soon as the weather improves......
MjrTom
Re: The CaK 80A filter arrives!
Post by MjrTom »
I look forward to your first light report and subsequent images :)
Post by Merlin66 »
I was going to set it up with the Herschel wedge....
Rusty: what do you mean "the red down to 20%"
andreahaku
Post by andreahaku »
Great news!
Waiting for your images then.
My 2 should be on their way... hopefully! :D
Post by Merlin66 »
Ahhh OK
I won't use a blue ERF...I'll have it behind the Wedge.
Andrea...I thought the version I was buying could see through clouds, leap tall buildings and make coffee....apparently I was mis-informed!
andreahaku
I thought mine creates a small Sun inside the scope!
Isn't so?! I want my money back :D
Has thanked: 20732 times
Been thanked: 10427 times
I tried with a wedge - too faint doesn't work. Ideally use a suitable 'blue' filter as a sub-erf.
Post by Merlin66 »
Hmmm,
The quoted transmission is around 30%, the camera sensitivity down in the UV is about the same and the surface reflection from the wedge is about 4%....
I'd just dump the ND3 and leave it out or replace with the ND1.8.....
Been thanked: 1 time
Post by swisswalter »
Hi Ken
great, I'm looking also forward to seeing your report on the first light
Tried this with the Baader K-Line which has much higher transmission than the Omega filter and IMHO was still too faint... I'm currently shooting 1/2000sec exposure with minimum gain by using a blue ERF instead...
Post by Merlin66 »
The eBay filter according to the curves has a bandwidth FWHM just less than 80 angstrom.
Mark: Point taken...let's see what happens....
THe Ebay filter is a veritable bargain (compared to the Baader KLine) and should give very comparable results :) :) :) I'm like you Ken, just waiting for the sun to return for long enough to play with all these mods - keeps me out of mischief! :whistle: :cheer:
alex
Post by alex »
Mark do you have a link to that filter?
Thanks
Alex
Thanks
Alex
[ebay]150751583708[/ebay]
oldfield
Post by oldfield »
highly interested in this filter, waiting to see your results!
just surprised to learn that it's too dim even behind a herschel wedge.
BTW, will it take parallel rays in order to work well?
colinsk
Post by colinsk »
So CaK is about 4.5 A wide. Beyond that you have blue filter for white light observing.
etatsolarchat
Post by etatsolarchat »
So did this filter work with the wedge?
Also seems they are sold out :(
Post by Merlin66 »
I've been clouded out here in Belgium since it arrived. Maybe next month?
andreahaku
I tested them. I have two and I tested both single and double stacked and tilted. Results are good. Certainly not like having a "real" CaK filter but they work quite well. I also don't have the Baader K-Line so can't compare. But I think results are more or less the same by looking at the pictures I've found online made with it.
So for what they cost, they do a good job. As soon as I'll have some time, I'll get back to imaging and forum and I'll post some of the pictures taken with them.
Andrea
etatsolarchat
Hmm, is double better? If not maybe you want to sell me one B)
So you did this with a wedge and there is enough light?
andreahaku
I tried two to try to reduce the bendwidth. It's a little better.
You can find the spectrum of the filter (single) in my blog (http://observingthesun.com/2012/04/16/a ... spectrums/). I didn't had the time to do the double stack/tilted one.
In the blog you'll also find one of the fist picture I took a few weeks ago with a single stack.
I use an handmade Herschel Wedge (2") and it works well even in single stack.
I don't think I'll sell one... but I'm sure that Bob will bring more to eBay. Try emailing him ;)
etatsolarchat
So where's a cheap source for filter holders 25mm filter in a 1.25in holder?
Also where did you get the 1200 l/mm grating on your DIY_USB_Spectroscope? I'm going to have to try that setup..
Post by Merlin66 »
Surplus Shed sell the 1.25" filer holders...
A couple of wraps of gaffa tape on the edge and the 25.4mm (1") filters will fit!
I get all my gratings from Optometrics....
andreahaku
I got the filter holders from Bob on eBay along with the filters. Don't know if he still got some more. And the diffraction grating from eBay as well. It's not a great quality one and I payed a very few euros for it. But it works great for the use I do of it.
The USB Spectroscope is very cheap, easy to do and useful if you use astronomy filters like I do to improve the quality of your images.
PEterW
Has thanked: 1 time
Been thanked: 6 times
Post by PEterW »
Always good to have a range of lower ND with a wedge in case you need to let more light in. Mark, 2000th second exposure?! What scope,filter and camera do you have, I though CaK was faint?
PEterW
sullij1
Post by sullij1 »
Hey, WAAA you guy's buy em out before you posted? It aint right! :?
Look Up!
etatsolarchat
Actually thread started before they were gone... I've already asked them to relist so we'll see if he does...
sullij1
Post by sullij1 »
Cool, thanks, don't know how I missed this thread. Been looking for a CaK that is affordable for months. Hope he puts more up. I emailed him too.
Look Up!
sullij1
Post by sullij1 »
He has more up Now! YAHHH! Snagged one!
Look Up!
sullij1
Post by sullij1 »
BTW; Everybody, thanks! :bow: :)
Look Up!
oldfield
Post by oldfield »
I got mine as well, I'm using it along with Baader 3.8, a side by side comparison with a 80A blue and an ebay CaK
Post by Merlin66 »
Oldfield,
Well done!
Excellent comparison which clearly shows the benefits of the Omega filter.
All we need now is a similar comparison with a single and double stack Omega....
sullij1
Post by sullij1 »
I picked up 2. Iwas going to give one to my son. I will stack them up when I get them and post the results. He has been engauged in his 20 other hobbies latley anaway. :)
Look Up!
colinsk
Post by colinsk »
Remember we want off band transmissions on the order of .001%. These graphs are not very useful.
sullij1
Post by sullij1 »
Rusty,
Thanks for the 411 on how to get this done. Just picked up the 400bp10. :bow:
You are a foutian of knowledge. Is the blue ERF needed with this setup?
Look Up!
sullij1
Post by sullij1 »
Is the 390 neccessary? How should the stack Look? Can the UV/Ir block be used instead of the 390? Just want to get it right. Sorry for all the questions. Example:
1. Solar film or BERF> UV/Ir cut> 400Bp> CaK> 390
2. Solar film or BERF> UV/Ir cut> 400Bp> CaK
3. Solar film or BERF> 400Bp> CaK> 390
4. Solar film or BERF> 400Bp> CaK>
Look Up!
sullij1
Post by sullij1 »
U R Da Man!Thank you for taking the time.
Look Up!
