Shortening the eyepiece holder?
Has anyone shortened the eyepiece holder to gain more in travel for focusing? A local machine shop can do it and even add another hole for the screw to hold the eyepiece. I was thinking about 10mm shorter.
- Has thanked: 173 times
- Been thanked: 615 times
Re: Shortening the eyepiece holder?
Yes, this has been done many times. Usually less than the 10mm you suggest.
The nosepiece of your camera may also need to be shortened, and your eyepieces may "bottom out"
What would be ideal would be to reduce the size of the part below the eyepiece holder to really increase focus travel. No problem with the cut but reproducing the threads for the eyepiece holder is the problem. Anyone know of a machine shop that can reporduce those threads? Thanks.
Jim
Jim
You can cut out a portion of the eyepiece holder and then make an outer sleeve to rejoin the two parts at the new shorter length.
That is a good idea. I would make the cut myself but don't want to mess it up. You say the eyepiece holder. I hope you meant the part that screws into the black box. Will this affect anything else except focusing? Thanks.
Jim
Jim
I just took 5mm off the top of my ep holder with a hacksaw. Then drill and tapped a small hole for a new screw. It was a fairly painless procedure and allowed focus with my DMK cameras.
Allan
Thanks. That makes me feel better but I have tried to cut stuff before and I can never get a straight cut so off to the machine shop it goes. What about cutting down the ERF holder? I would think that would be even better.
Jim
Jim
This is the mini ERF holder that screws into the black box.
Leave it alone.
This is the eye piece holder, it's what holds the eye piece, it screws into the tube that holds the mini ERF.
This one has been shortened and a second lock screw added.
I read where you had ordered a short nose piece for your camera. It doesn't work?
Leave it alone.
I have ordered it but it has not arrived yet. Can you explain why I should leave the mini ERF alone? Thanks.
Jim
Jim
Jim. If you use the external sleeve method the cuts don't have to be particularly accurate. Provided that the sleeve is a reasonable fit and the ends are square then it will hold your cut pieces square, no rethreading or new drilled holes.
There's only about 18mm between the cell holding the mini ERF and the threads needed to make the connection to the EP holder.
You go cutting that part to shorten it and try to make a sleeve to joint the parts together again you get into some limited operating room. A "sleeve" would have to be machined to close tolerances plus drilled and tapped with holes at both ends for set screws to lock everything together.
Then you are changing a design dimension in the optical train which has been advised against over and over.
There's nothing to be gained by such a project and much to lose.
What I had planned to do was have a machine shop make 2 cuts and then join the screw parts together - thus shortening it. I would keep the middle piece in case I have to add it back on.
Jim
Jim
Give up on all those wild ideas and just stick a barlow in it.
Generally a PST can handle 2-2.5X without a problem.
I used a TV2.5XPM 99% of the time, even after I built the mini stage 2.
Or look at the special camera adapters Siebert Optics offers.
- Has thanked: 20424 times
- Been thanked: 10243 times
Why not just wait and see if this works first
The mini ERF looks like it can unscrew from its holder. Has anyone done this before? I cannot get it started turning.
Jim
Jim
Yes, i've removed several. Use a lens spanner, makes the job easy.
Hi Jim
yes, I highly recommend a lenspanner, makes modding that much easier
