I have been wondering whether a DS2 internal etalon for the 80mm scope would physically fit to a 60mmTha.
Not sure if the tube dimensions are the same.Perhaps someone with both scopes could give this a try,and see if it actually works. :thanx:
Internal double stacking a Lunt 60Tha with a 80mm DS2
- pstew
Re: Internal double stacking a Lunt 60Tha with a 80mm DS2
Did try this a while ago, they do fit together but the DSII doesn't fit completely into the 60.
If I remember correctly the view wasn't worth the effort
Paul
Timaru, New Zealand
LS152Tha/B34/DSII, LS80THa/B18/DSII, LS60Tha/B12, Grasshopper3(ICX687), Chameleon 3(IMX264)
Timaru, New Zealand
Gentelmen, I confirm that LS60Tha works very good with LS100 DSII module. I checked it 10 minutes ago
Minor ghost effect and glowing. Surface detail is much improved as it should be in double stack. Proms and active regions are very contrasty.
- Has thanked: 20424 times
- Been thanked: 10243 times
Very good!
Hi Pawel
what a fine mod
what a fine mod
Does the LS100 DSII module has an collimation - refocusing optics?Pablito wrote:Gentelmen, I confirm that LS60Tha works very good with LS100 DSII module. I checked it 10 minutes ago
What is the aperture diameter of this module?
Thanks,
Valery.
Yes Valery, it has these lenses. Clear aperture is 35mm.
Many thanks, Pablito!Pablito wrote:Yes Valery, it has these lenses. Clear aperture is 35mm.
