Anyone know if pst etalons can be fixed?
Re: Anyone know if pst etalons can be fixed?
Thanks guys. Some really good plans coming together here. Im going to try them all
- sullij1
Hi, it is my understandng that water is the method used to seperate the spacers not recontact them. Oliver does this suff for a living, I would go with his advice.
Look Up!
I know that, that's why I think a drop of water would allow correct positioning of the halves and on evaporation might allow the bonding to take place.
Just a thought really, from my experiences seeing highly polished parts seeming to get glued together after being damp and allowed to dry while in contact.
I picked up some acetone and a bottle of 99% isopropyl alcohol. That all I can find. Which do you think is better for the re-contact effort?
- Has thanked: 174 times
- Been thanked: 619 times
I've been using the Acetone for my attempts at repair....
Rob - There is a person in Ontario that may be able to help you-eh. His name is Vaz Zastera of ZARTWERKS Studio in Merrickville, Ont-eh. A while back he had a video showing how optical contacting works, and I thought that I'd seen it on this forum-eh. He is a sculptor not an astronomer, but he may be able to help with your etalon-eh.
His website is http://www.zartwerks.com/ and a video about optical contacting is available on his site or youtube at http://www.youtube.com/watch?v=8nejla9u ... bedded#t=0 . Again, this is NOT the video that I had seen of him optically contacting glass-eh. I have that other video and would have attached it here, but it is about 24 MB big and too large to be uploaded to this site-eh.
He uses methanol to clean the glass and about a full box of lens tissue-eh. The video is worth seeing even though it is not an etalon contacting-eh. I'll search for a while to see where it might be archived and let you know-eh.
Too bad this site has small file restrictions-eh.
SolarJohn
SolarJohn
Now THAT was a video worth watching!!!
Love it!
Love it!
That is super interesting, thanks.
So, the cleaning has to be absolute!
To get 2 pieces of glass polished so one will float over another on trapped air is amazing and has to be where the time and skill comes in.
Now I have another question. I wonder if the air spaced etalons we deal with are only bonded at the slivers providing the separation?
Could that help explain how pressure applied to the etalon changes its tuning?
The plates are flexing on the bonded support pieces?
John,
Note that no pressure was used to get the bond..as the "gap" diminished (due to the evaporating spirit?) they just did their thing.
IMHO the etalon plates are far too thick to flex -under the loadings we can apply.
We don't know how...yet....but the spacers appear to "give" under applied pressure and change the tuning....white man's majic??!!
The direct question was asked regards the PST etalon....
QUOTE
I do not believe that there is a patent on the tuning of the PST. At least I did not help write one while I was at Coronado.
The etalon is tuned via mechanical compression (squeezing) and not tilt. It is a similar concept to the current RichView tuning system.
Best Regards,
Andrew Lunt CEO
UNQUOTE
QUOTE
Best Regards,
Andrew Lunt CEO
UNQUOTE
A foam disk/small foam block at one side and an 'O' ring at the other.......
- sullij1
Hi etalonfriends,
I have already successful repaired an PST etalon with his four spacers and an Solarmax 40 front unit with new spacers.
You need follows working tools:
- pure alcohol or "Sidolin" window cleaner (streak free)
- wooden toothpick
- polishing cloth (100% cotton, clean and soft)
- thin tissue paper
- normal copy paper
- black base for working (Velour black)
1. Mark the correct position the plates to each other (if doesn't exist)
2. Clean the etalon plates with alcohol and please leave fixed spacer stay tuned.
2.2 Loose spacers please very careful clean by ligthly press with the cloth.
3. If all cleaned, place the etalon plate with the least number fixed spacer down on base and then drip little alcohol on etalon (up to surface is thin full covered).
4. Cut a tissue paper stripes and place on full etalon surface.
5. Put the second plate slightly on correct position on the tissue paper and pull out this paper.
6. Observe the optical contacting process on spacers - light color from white to black.
If doesn't contacted spacer, you see rainbow colors (Newton fringe).
7. When both etalon plates are full contaced with all spacers, then pull or slide copy paper stripes between the plates to absorb the rest of alcohol.
Loose spacers must contact individually with same process. For correct placing on thin alcohol film or tissue paper stripes, helps the toothpick.
As new spacers, I have used precise quartz waveplates with around 0.19...0.23mm thickness. Crushed by press makes some spacers.
Btw, I have repaired the etalons in my kitchen on kitchen table. B)
If I have more time, I will make add. photos to some steps.
I will be one who adds karma points for your assistance. Thanks
- wooden toothpick
- thin tissue paper
- normal copy paper
Look Up!
I will too if it works!
But what do I care.... I only have 5 hmy: HahahahahahahHHHA :whistle:
Just got in from a very long day at work....been reading emails as they came in...but its 2:45am and I need sleep. Thanks for all the great responses! I cant wait to try them and see the videos! Many thanks for all of that stuff!
1 more night shift to go so I apologize for late responses in advance! :
That is a great video! About 100 bucks in tissue...... But a really great tutorial! : thanks for that!
That was a very interesting video. So the cleaning has to meticulous, can you imagine how you are going to do that with those tiny spacers. hmy: You can barely see them, let alone clean them.
John; I wouldn't worry about how the tuning is done, it will do your head in.
Allan
- sullij1
Here ya go Rob - Make it 6! Just for reviving the conversation.
Look Up!
: : : Wooohooooo pity karma! :woohoo:
Lol just kidding. Its for the etalon....
Gee, that's an old message - from the archives when Colin and I were learning our way....
Hi all
what a great thread. I'm on the way in my lab and I will run a scan on a spacer, then we will now its composition
Thanks for that info Walter! Im going to attempt contact again today.... Its sunny but cold here so ill play with flammables inside instead of freezables outside today!
