PST Mod Question
PST Mod Question
Post by marktownley » Sun Feb 26, 2012 7:51 pm
I know this may seem a daft one but will ask anyway... If I was doing a PST mod and unscrewed the gold objective tube from the black box, I could screw it back on again if I wanted?
Roel
Oh, I get it now!
Oh, I get it now!
Re: PST Mod Question
Post by Roel » Sun Feb 26, 2012 8:01 pm
Yes, no problem!
(But remove the sticky Loctite if present, it might glue back on almost as tight as before! The newer PST's have lots of this nasty stuff on all threads))
My sketches, observations and ATM projects: www.roelblog.nl
Post by swisswalter » Sun Feb 26, 2012 8:59 pm
Hi Roel
Yes you are right. I did it my self. I felt, if you put it together again it sticks much better together, I was almost not able to deassemble them again
DSobserver
Post by DSobserver » Mon Feb 27, 2012 8:01 am
in order not to damage the gold tube, I recommend to use this special key : http://www.waterconcept.fr/cle-boa-smal ... p-709.html
occamfan
Post by occamfan » Fri Mar 02, 2012 9:14 am
I found that these tools did the trick;first putting the black box in a vise(cushioned with wood and leather) and using an oil filter removal tool around the gold tube,this time cushioned with thick rubber(an old engine a/c belt)
I found that the tube and etalon came free from the black box together, so I mode shaped wooden grips to hold the etalon in a vise then used the same technique to separate the tube from etalon - heres a pic. of the whole tool kit
Have fun!
Post by Merlin66 » Fri Mar 02, 2012 10:55 am
So far so good....
Just double check the etalon...make sure the front and rear lenses are still tight in place (I had a couple of examples where they had loosened during removal)
Looks like you're heading for a Stage 2 mod....
poita
Post by poita » Wed May 30, 2012 10:16 am
I snapped two heavy duty boa's, I never managed to get the gold tube off my second PST.
