Do I still need to use a UV / IR cut on KG3 filter?
uplooker
Post by uplooker »
I bought one of Oliver's UV / IR cut on KG3 filters to use on my TAl 100RS Stage 2 PST mod as the PST that i used was one of the early ones that did not have an ITF at the bottom of the EP holder.
I have recently upgraded to a Coronado BF10.
Do I still require this UV / IR filter?.
I would appreciate your thoughts and clarification on this.
Thank you in advance
Ian
Has thanked: 20442 times
Been thanked: 10248 times
Re: Do I still need to use a UV / IR cut on KG3 filter?
Simple answer, No! :)
Has thanked: 173 times
Been thanked: 615 times
Post by Merlin66 »
Ian,
The built-in ITF filter at the front of the BF10 replaces the KG3 etc....
Keep it for the next mod ;-)
uplooker
Post by uplooker »
Thank you very much Mark and Ken for the replies. I thought not, just wanted to check.
Ian
