Hi all,
I bought one of Oliver's UV / IR cut on KG3 filters to use on my TAl 100RS Stage 2 PST mod as the PST that i used was one of the early ones that did not have an ITF at the bottom of the EP holder.
I have recently upgraded to a Coronado BF10.
Do I still require this UV / IR filter?.
I would appreciate your thoughts and clarification on this.
Thank you in advance
Ian
Do I still need to use a UV / IR cut on KG3 filter?
- Has thanked: 20783 times
- Been thanked: 10473 times
Re: Do I still need to use a UV / IR cut on KG3 filter?
Simple answer, No!
- Has thanked: 174 times
- Been thanked: 619 times
Ian,
The built-in ITF filter at the front of the BF10 replaces the KG3 etc....
Keep it for the next mod ;-)
Thank you very much Mark and Ken for the replies. I thought not, just wanted to check.
Ian
Ian
