Will this scope work
axle01
Post by axle01 »
I just received a Skywatcher SW102/500 to mount a SM90 and BF15 on but I just came across a Black Tube Orion 120mm x 600FL F5 OTA and wondering if it would be good for full disc viewing.
I have a dual mount and thought the SW 102 with the SM90 on one side and the Orion 120 with a Baader Herschel Wedge on the other side of the dual mount.
Thoughts please.
Alan
Has thanked: 174 times
Been thanked: 618 times
Re: Will this scope work
Post by Merlin66 »
Either of those scopes would work well for solar, but getting the full disk images will come down to the size of the chip in your camera...
The sun's disk is approx 1/100 the focal length ie 5mm or 6mm diameter - if the chip is larger than these dimensions you'll manage...if not then it's mosaics...
axle01
Post by axle01 »
I have the Grasshopper3 2.8 MP Mono USB 3.0 (ICX674) so how will that go.
Alan
Post by Merlin66 »
Alan,
According to the Datasheet, it has 1920 x 1440 pixel, 4.54micron.
This gives 8.7 x 6.5mm chip.
Should work well with either scope!!
axle01
Post by axle01 »
That's good news, thank you M66 I really appreciate your input.
Alan
axle01
Post by axle01 »
Thanks John.
Has thanked: 20732 times
Been thanked: 10427 times
Good info guys. Thanks.
axle01
Post by axle01 »
Ok so should I mount the SM90 on the Skywatcher SW102 x 500FL or the Orion 120mm x 600FL and the Baader Wedge on the other, then I can use the Grasshopper 3 on either.
Alan
axle01
Post by axle01 »
Thanks mate I will do that when the Orion arrives, I want to make sure before I get the SM90 adapter made for either of the scopes.
