New member starting pst mod
dgcclubmaker
Oh, I get it now!
Oh, I get it now!
Re: New member starting pst mod
Post by dgcclubmaker » Mon Jan 13, 2014 2:53 am
Hi All and Happy New Year! Its been a bit since I last updated. So, I have successfully disassembled my pst! I have also received my donor ota, Celestron 102 xlt, and should receive my Lunt 100mm erf this week. Im currently deciding whether or not to replace the stock focuser. I also have to work out the erf mounting. Im excited to complete this project so that I can start some imaging! Thanks for all of the assistance that ive received so far.
Ricky
Post by swisswalter » Mon Jan 13, 2014 5:07 am
Hi Ricky
great. Please pics ;-)
Post by marktownley » Mon Jan 13, 2014 7:09 am
Good work! Definitely, pictures 8)
dgcclubmaker
Oh, I get it now!
Oh, I get it now!
Post by dgcclubmaker » Sat Feb 01, 2014 12:24 am
Hello All!
Its been a bit since I last updated. I have everything completed except my choice of solutions for more in focus. As I see it, from my research, I can either shorten my ota, replace the focuser for one that is lower profile or maybe replace the bf diagonal for a straight thru solution. Im leaning towards the latter. Has anyone converted their Coronado diagonal bf to a straight thru version? A couple of other quick questions...how much tilt do I need to provide to the erf...ive read 1mm to maybe 2mm...is this correct? Lastly, since I have an external erf do I still need to use the mini-erf? Thanks for all of your help so far!! Im getting closer to first light!
Best Regards,
Ricky
What follows are pics of my setup as is...first up my Lunt 100mm erf.
dgcclubmaker
Oh, I get it now!
Oh, I get it now!
Post by dgcclubmaker » Sat Feb 01, 2014 12:26 am
Here's a pic of the etalon assembly...
dgcclubmaker
Oh, I get it now!
Oh, I get it now!
Post by dgcclubmaker » Sat Feb 01, 2014 12:27 am
Here's a pic of the front of the ota with the erf assembly...
dgcclubmaker
Oh, I get it now!
Oh, I get it now!
Post by dgcclubmaker » Sat Feb 01, 2014 12:28 am
Finally, here's a pic of the whole scope...
Post by Merlin66 » Sat Feb 01, 2014 3:10 am
Ricky,
Looks good.
The front ERF just needs a small tilt to reduce reflections and ghosting - 2mm would be more than enough.
The "key" is to have the etalon at the majic -200mm inside the prime focus. Once positioned, IT NEVER MOVES. This then means that the final focus will be 200mm from the etalon. You will need some sort of focuser after the etalon.
The ITF in the Coronado BF diagonal adds "belt and braces" to the ERF by further reducing the UV/IR. There's no real reason to remove it - leave it in place.
Why would you want to convert the BF to a straight thru? There's usually more than enough space (in the 200mm) for the diagonal and your camera etc.
Post by swisswalter » Sat Feb 01, 2014 8:02 am
Hi Ricky
fine pics a great mod. CS for the next days, we like to see pics from the sun
Post by marktownley » Sat Feb 01, 2014 8:59 am
Good stuff! Will look forward to seeing how you get on :)
dgcclubmaker
Oh, I get it now!
Oh, I get it now!
Post by dgcclubmaker » Sat Feb 01, 2014 11:56 pm
Thanks for the suggestions! I have finally procured a used Coronado BF15...coming all the way from New Zealand thanks to my friend Gary Beal!
Ricky
dgcclubmaker
Oh, I get it now!
Oh, I get it now!
Post by dgcclubmaker » Thu Feb 13, 2014 2:55 pm
Hi All,
Here are my latest mod pics...still waiting for my focuser.
Ricky
dgcclubmaker
Oh, I get it now!
Oh, I get it now!
Post by dgcclubmaker » Thu Feb 13, 2014 2:57 pm
The mod 2 simply replaces the pst black box with the focuser, extensions, and bf15...
Post by swisswalter » Thu Feb 13, 2014 5:01 pm
Hi Ricky
that looks great
dgcclubmaker
Oh, I get it now!
Oh, I get it now!
Post by dgcclubmaker » Thu Feb 13, 2014 5:42 pm
TY! Do you think im close enough to the 200mm mark?
Ricky
Post by Merlin66 » Thu Feb 13, 2014 10:52 pm
Ricky,
Probably close enough at this stage.
You'll quickly find out when you first use it. The focus position (at the black box eyepiece) should remain unchanged for what you had with the original PST.
Once correctly positioned you still use the focuser on the black box - not the one on the scope!
dgcclubmaker
Oh, I get it now!
Oh, I get it now!
Post by dgcclubmaker » Fri Feb 14, 2014 1:02 am
Thanks Merlin! Clouds have hampered my first light attempt...maybe next week sometime. Im still awaiting my JMI NGF-CM focuser w/DRO Controller. Currently, you'll notice in a pic or two above, I have a 2" sct visual back coming off the rear of the etalon. As has already been mentioned, the fit is less than perfect. I have wrapped Teflon tape around the etalon threads to snug things up a bit but its still not as solid a connection as I would prefer. Solarhound in a previous thread says the twist end of the Antares 2" twistlock threads on so I have a used one coming in. From whichever adapter I end up with I will attach a 2" to sct adapter which will in turn be attached to the focuser. The back end of the focuser will accommodate the BF15 (with the appropriate adapter)...this of course is the plan. LOL. As a side note, I accidentally stumbled upon a Point Grey Chameleon imager for a very nice price! We are getting close...
Best Regards,
Ricky
dgcclubmaker
Oh, I get it now!
Oh, I get it now!
Post by dgcclubmaker » Sun Feb 16, 2014 7:53 pm
Hi All,
First light! Not the best but its something! Im still awaiting my focuser. Thanks for all the help...its gotten me this far.
Best Regards,
Ricky
First light...
Post by swisswalter » Mon Feb 17, 2014 5:24 am
Hi Ricky
congrats on the new PGR Baby and a good start for the first light. The tuning of the etalon is a key next to the focusing
dgcclubmaker
Oh, I get it now!
Oh, I get it now!
Post by dgcclubmaker » Mon Feb 17, 2014 4:05 pm
Thanks! I was playing with the tuning and was able to catch a very nice prominence as well!
dgcclubmaker
Oh, I get it now!
Oh, I get it now!
Post by dgcclubmaker » Tue Feb 18, 2014 3:52 am
Hi All,
Just received the last piece to complete my PST Mod2...the NGF-CM electric focuser! Looking forward to some sunshine now.
Ricky
Post by Merlin66 » Tue Feb 18, 2014 4:02 am
Ricky,
Certainly looks sexy, and probably overkill...
Watch the total length of the stack....
Based on previous builds the distance from the rear of the PST etalon to the front face the BF10 should be very close to 120mm (if you want to image) - this gives the final distance to sensor at 200mm.
dgcclubmaker
Oh, I get it now!
Oh, I get it now!
Post by dgcclubmaker » Tue Feb 18, 2014 4:13 am
Thanks Merlin. I think I can shorten the stack a little. I got the focuser for cheap with dro controller. Crossing fingers.
Best Regards,
Ricky
PS I reprocessed my first light solar image and include it here...I like it much more.
Post by swisswalter » Tue Feb 18, 2014 5:24 am
Hi Ricky
that looks great and congratulations on the rework. Now you are very close to good pics
dgcclubmaker
Oh, I get it now!
Oh, I get it now!
Post by dgcclubmaker » Tue Feb 18, 2014 4:21 pm
Ok..based upon some words of wisdom from Merlin here is a bit of rework on the rear stack of my ota. Fully racked in I get very close to 120mm to the bf15 diagonal from the rear lens; fully racked out I get 140mm. Now for some sunlight to test her out!
Best Regards,
Ricky
