Where is delete button?
I want to delete a post, dont see the way to do it?
Chris Schur
Re: Need help with my new DBK camera!
Hi Chris
have you also made a run with firecapture
- Been thanked: 4422 times
Re: Where is delete button?
Hi Chris...
Not sure if you found the answer to this, but if you look in the lower right of your post there is an X button to delete the post and an ! next to it to report it.
Hi Chris
why the hell you want to delete it ?
