I came across this field of view calculator before - it's pretty good I think with a decent database of both cameras and scopes. There's an option to put the sun in as the object too. You can drag the solar image around the view box to get to the limb...
http://www.skyatnightmagazine.com/field-view-calculator
I'll leave it in the main forum section for a day or two so people see it, then put it in the library.
Hope it's of use!
Field of View Calculator
Moderator: marktownley
- Has thanked: 20783 times
- Been thanked: 10473 times
- solar
- Has thanked: 217 times
- Been thanked: 1369 times
Re: Field of View Calculator
Thanks Mark, these things are always handy.
Vixen 130ss SolarMax 90 BF30 EQ6 Pro, LX200 14, C8 CG5, Megrez80, Lunt 100 DS. EQ 8
ASI 120mm 290mm 432mm Lunt B1800 Cal-K + other stuff.
Skywatcher 150mm PST Mod2
Yep very handy I just had a go with a few settings and saved the link to the desktop, ta much Mark.
Alan
Hi Mark
thank you very much. Very handy
I found one because I wanted to know what the fov would be with a 100mm f10 scope and a quark (use 4.2x mag factor) - it's pretty small!
